Subdivision + displacement test
- drBouvierLeduc
edit : Damn, too slow at typing
Yeah, in the modifier you have to enable that option manually ("backface culling"), depending if you have glass materials or not.
So I guess in Indigo you would need to have some automatic checkup to see if the mat is transparent or not before applying bakface culling.
But I think we can live without backface culling !
Keep up the good work.
Mmmh, another completely non-educated comment from me. But as someone who needs to render at pretty high resolution, I'm a bit wary of solutions that mean more memory consumption and even slower render times.
The exhibitionist bathroom I posted earlier was rendered with a width of 1,600 pixel (as opposed to the 2,400 pixels I use normally). Even so, it crashed Indigo on my 32 bit systems and needed Indigo 64 bits and 4gig of RAM to render. And it was still far from clean after 20 hours.
- PureSpider
After further convergence...
You can see a little bit of 'triangle facet aliasing' around the highlight on the sphere, but it's not too bad. And this was using ~300,000 tris, using something like 150 to 200 MB memory for the Indigo process.
Render speed is also tolerable. (> 200K samples/sec)
I think the worst case for a complete micro poly approach would be highly specular reflections from high curvature surfaces, like chromed taps or something like that. IN that case the triangles would have to be significantly smaller than 1 pixel, otherwise the mesh is going to look like a disco ball
EDIT: and unfortunately picking out the highlight for some kind of adaptive subdivision is impossible (in general) before the render takes place
- im1210866737.png (733.16 KiB) Viewed 3589 times
The problem you have looks somehow like the ones of realtime terrain renderers (like crysis too). There the triangle density depends on the distance to the camera and the jagginess of the terrain. Would be cool if you could build in such dependencies. Also it would be cool if the subdivision algo could cut irregular, too long triangles in two pieces to make the whole geometry more regular, instead of cutting every triangle the same.
- quad subdivision.PNG (963 Bytes) Viewed 3532 times
An example of dynamic data management, even thought I never heard about this one before. That's an dramatic case of management to me, single computer user.
And if you where tempted to ask, no I haven't suscribed to their serviceThis work effectively tackles issues related to load balancing and memory allocation by a master-slave paradigm
- Kosmokrator
- drBouvierLeduc
Users browsing this forum: No registered users and 80 guests
