Cindigo 0.9 - beta 1
Marcofly
Post by Marcofly » Mon Aug 27, 2007 8:57 pm
post the file, if you want.. without furnitures and mats..
Alain
Post by Alain » Mon Aug 27, 2007 9:41 pm
ok, here it is...
Sunlight_position.rar
(68.45 KiB) Downloaded 212 times
Post by Zom-B » Mon Aug 27, 2007 10:10 pm
Hey Alain.... no Offense, but please start a new Thread at the "Work In Progress" Subforum and keep this Thread for Cindigo Developement & Bug Reports...
Marcofly
Post by Marcofly » Mon Aug 27, 2007 10:44 pm
ok, i made a quick test.. it works fine.. i suggest you to put the model near the 0,0,0 coordinates. I don't see the reason why you should keep the glass on the windows, but i left it..
i always use a camera target, to have better control on the DOF.
I do mark the 'export settings to xml', to correct-change the settings of the .igs file quickly..
you can set the MNCR and the Max Depth low, for the tests, (check my file).
don't forget to insert the line <gamma>2.2</gamma>, after the material glass, otherwise Indigo gives you an error..
ciao!
:wink:
Sorry, ZomB, we posted at the same time.. :oops:
Alain.rar
(82.87 KiB) Downloaded 237 times
a 12 minutes rendering..
CoolColJ
Post by CoolColJ » Mon Aug 27, 2007 11:25 pm
MNCR makes no difference to render speed as I proved with my render modes thread, but max depth does a little with glass/SSS :)
Post by fused » Fri Aug 31, 2007 3:35 am
update!
CINDIGO 0.9 - BETA 1
download exporter:
PC Version
(or below)
The file contains PC versions for R10 and R9. (R10 users will have to rename the "cindigo0.9.1.cdl_R10" to "cindigo0.9.1.cdl")
No Mac version to come, sry.
new in 0.9 - beta 1:
* no more object tag (normal smoothing is on if the object has a phong tag, if "visible in render" is of object doesnt get exported)
* new material tag (materials created with older versions might be incompatible)
fixed-list 0.9 - beta 1:
* gamma ;)
known bugs/issues 0.9 - beta 1:
* only UVW-mapping supported
* nurbs should be made editable
* rotation bug still there
please post bugs :!: :!:
a good tutorial can be found here (only german and italian, hope someone will translate it to english soon).
extraextra: a little baking tutorial
cindigo0.9b1_3.zip
Cindigo 0.9 - Beta 1
(452.54 KiB) Downloaded 36681 times
Marcofly
Post by Marcofly » Fri Aug 31, 2007 4:08 am
thanks fused!! :lol:
just a question: if i set a specular mat, transparent true, the default rgb absorption is 1,1,1. Shouldn't it be 0,0,0?
Post by Zom-B » Fri Aug 31, 2007 6:17 am
Hey Fused... A great release with a lot of new Features!!!
Poorly atm I've got no time for a "deep scan", but I'm sure the isn't much left to fix anyway :lol:
But I just discovered, that "Absorption Spectrum Type" and "Scattering Spectrum Type" can be set also to Peak and Black Body?!?
CoolColJ
Post by CoolColJ » Fri Aug 31, 2007 11:20 am
was the normals flipping fixed?! :)
Post by Zom-B » Fri Aug 31, 2007 11:45 am
CoolColJ wrote:was the normals flipping fixed?! :)
yes :)
manitwo
Post by manitwo » Fri Aug 31, 2007 4:18 pm
fused wrote: * no more object tag (normal smoothing is on if the object has a phong tag, if "visible in render" is of object doesnt get exported)
my dream came true :D
CoolColJ
Post by CoolColJ » Fri Aug 31, 2007 6:13 pm
Downloaded: 36282 Time(s) :?: :!:
Pinko5
Post by Pinko5 » Fri Aug 31, 2007 7:17 pm
Tnx Fused very good work!!!
Pinko. ;)
CoolColJ
Post by CoolColJ » Fri Aug 31, 2007 7:35 pm
Hooray you fixed the normals shading?
so how do we remove smoothing?
Marcofly
Post by Marcofly » Fri Aug 31, 2007 8:05 pm
just delete the c4d phong tag :wink:
