Indigo Renderer 4 public beta
Nikolaj Knudsen
Post by Nikolaj Knudsen » Fri Apr 08, 2016 9:14 am
:) sweet
Arthur 2.258M
Oscar 5.105M
GTX970
Post by pixie » Fri Apr 08, 2016 9:19 am
I got one scene working! :D
Post by Oscar J » Fri Apr 08, 2016 9:35 am
Thomas/lycium has confirmed it is OpenCL 1.1 minimum. So the issues you're having are probably more related to memory limitations pixie. The benchmark scenes we posted are both pretty heavy, having several million triangles each. Good to see it works with simpler scenes. :)
Post by neo0. » Fri Apr 08, 2016 9:50 am
Thar she blows! Finally! Normal cpu rendering seems quite a bit faster. When i enable gpu rendering it just says "building open gl kernel" and nothing happens! Should probably have some sort of a progress bar for that. Material previews should be horizontally centered as well. Geforce 630
burnin
Post by burnin » Fri Apr 08, 2016 10:46 am
Oscar J wrote:Thomas/lycium has confirmed it is OpenCL 1.1 minimum. So the issues you're having are probably more related to memory limitations pixie. The benchmark scenes we posted are both pretty heavy, having several million triangles each. Good to see it works with simpler scenes. :)
OK, got it working with caterpillar_5... and it is fast!
Tho lots of crashes, hangings and even BSoD.
Anyone can advise a good tool to monitor system?
afecelis
Post by afecelis » Fri Apr 08, 2016 1:48 pm
Thanks a lot Ono! :D :D
Do we have to uninstall version 3? Is this stable enough for production?
I'm geting "QtNetwork4.dll/QtOpenGL4.dll/QtSql4.dll missing" error after installing RT and trying to launch it.
I'll post my benchmark, but what's the criteria? Time/samples/render method? Or is it just opening the file and let them render?
cheers,
Alvaro
Ps. I pasted them from another 3d app but got the following error (Image attached)
snorky
Post by snorky » Fri Apr 08, 2016 7:04 pm
Oscar J wrote:Snorky, not sure but have you tried installing CUDA? I know Zom-B got a GTX 660 working fairly well.
....failed
I have tried to instal v3.8.x but I have the same problem... Could the latest gpu driver be the problem?
EDIT:
362.00 work! :)
Post by zeitmeister » Fri Apr 08, 2016 8:08 pm
362.00? Similar problem here... will try that.
Cheers, zeiti
Post by CTZn » Fri Apr 08, 2016 8:20 pm
afecelis wrote:Is this stable enough for production?
No no no no, that will be in quite some time, beta does mean beta ! It took several years for 3.0 to go from first public beta stage to "stable".
Hoffy Luck !
Post by pixie » Fri Apr 08, 2016 8:28 pm
Even the low memory scene kindly ceded by Originalplan® failed to open. :(
Originalplan®
Post by Originalplan® » Fri Apr 08, 2016 8:29 pm
Hoffy Luck !
It is ready for play and reporting problems back. :)
Post by Zom-B » Fri Apr 08, 2016 8:56 pm
I actually work with the v4 beta in production from Day one!
The CPU renderer is faster now and does a great job running stable for me and my 2 Renderslaves.
The GPU renderer indeed always misses some features that I need for a project, but the CPU part is great...
There is also no need to uninstall v3! I always install new Indigo versions in a new folder with version number and thereby can always use the earlier version if sth is not working or do benchmarks between the different versions.
contegufo
Post by contegufo » Fri Apr 08, 2016 9:13 pm
Hi
What's different in the latest beta 4.0.30?
Post by Zom-B » Fri Apr 08, 2016 9:16 pm
* Showing 'trial expired' dialog at most once per execution.
Post by pixie » Sat Apr 09, 2016 12:25 am
This scene despite having a low memory footprint I cannot make it render either... :(
PS: it renders on CPU, but it renders different then the original path. And makes quite a jump, from 200 to 700Mb Ram usage! o.O
Users browsing this forum: No registered users and 52 guests
