SkIndigo 3.0.15 (beta)
Re: SkIndigo 3.0.15 (beta)
Post by Whaat » Thu Feb 23, 2012 3:25 pm
cotty wrote:
Voytech wrote:I tested on (skindigo) 3.2.5 and the newest build of Indigo (3.2.8 ). Still there.
Me too:
Indigo Renderer v3.2.8, Windows 64-bit build
SkIndigo 3.2.5 Released 7 Jan 2012
Hi cotty,
The issue has to do with your curvature threshold setting. Areas with less curvature are getting subdivided less than other areas which results in smoothing artefacts. You should set it to 0.0 in your case. The default setting of 0.1 is usually good for situations where you are subdividing for the purpose of displacement mapping. However, if you are subdividing and smoothing in order to get a super-smooth mesh, you should set:
1. curvature threshold to 0.0
2. Turn view dependent off
Also, six subdivisions is major overkill on this mesh. 3 should be plenty.
You will find it extremely helpful to change the material to diffuse, and then enable 'random triangle colors' in the Indigo GUI. This will let you see the effects of your subdivision settings.
Cheers,
Dale
cotty
Post by cotty » Thu Feb 23, 2012 7:34 pm
Whaat wrote: 1. curvature threshold to 0.0
PERFECT! (I have never dared to change the default options somewhat :? )
Whaat wrote: Also, six subdivisions is major overkill on this mesh. 3 should be plenty.
YES! (see picture)
Whaat wrote: You will find it extremely helpful to change the material to diffuse, and then enable 'random triangle colors' in the Indigo GUI. This will let you see the effects of your subdivision settings.
I never noticed this option before and yes, I find it extremely helpful and will use it very often from today...
Thank you very much for your help!
ninopiamonte
Post by ninopiamonte » Thu Feb 23, 2012 9:30 pm
Thanks Whaat!!!
Love the new features of this beta release, especially the exporting to Indigo. It's fast.
penkroff
Post by penkroff » Sun Apr 08, 2012 8:41 am
Why is the component "dummy"option not working? :roll:
cotty
Post by cotty » Sun Apr 08, 2012 8:43 pm
Here is a little example of different subsivision values...
