DEV-thread - Blendigo v0.7 - material-editor-exporter
SmartDen
Post by SmartDen » Mon May 07, 2007 9:45 am
I could do it. But you've right we have to decide what way we go, with same of different variables for each sort of material. The idea is actually not bad but requires more code lines ;)
zuegs
Post by zuegs » Tue May 08, 2007 7:29 am
i think it's not important if we have 1 or 2 variable-sets. 2 seems to be simplier i think.
Soon i will come up with the XML library :D - then all material data are stored as indigo XML datablocks inside blender scene. So it will be possible to save or load "*.igm" material-files. 8)
The access from GUI buttons to internal data will go over an interface that allows calls like:
xml.readValue("material.diffuse.colour")
xml.writeValue("medium.basic.absorption_coefficient_spectrum.rgb.rgb", "0.3 0.4 0.5")
as you see, all access needs to use the indigo XML material structure. In this way the materials are directly ready for export 8) :D
The big disadvantage will be that we need to completely rewrite the internal GUI stuff :cry: , but then it will be up to date and quite flexible for future extensions in Indigo-materials :twisted: :D
Post by Kram1032 » Tue May 08, 2007 7:30 am
:D will it also be faster?
You also will have to rewrite your exporter, when 2.44 final appears:
it has a great SSS-material tab, that also could be used :D instead of strangely increasing/decreasing such things like "limit" in Ray transparency part....
it everytime should be 100 in my oppinion...
But it's great, though :D
eg2k6
Post by eg2k6 » Tue May 08, 2007 2:10 pm
the preview button doesn't work for me.
does this work on 0.7 final?
joegiampaoli
Post by joegiampaoli » Tue May 08, 2007 3:02 pm
eg2k6 wrote:the preview button doesn't work for me.
Did you copy the preview folder to your indigo dir? Or set up a preview scene of your taste?
Joe Giampaoli
My Indigo Gallery
eg2k6
Post by eg2k6 » Tue May 08, 2007 3:05 pm
i copied it to my indigo dir.
joegiampaoli
Post by joegiampaoli » Tue May 08, 2007 3:07 pm
hmmm that's strange, by any chance are you using linux, I had an issue with the folder name and renamed it previews all in lower case, I think DaveC fixed that, just check to make sure.... Otherwise something probably not set up correctly in your side
Joe Giampaoli
My Indigo Gallery
eg2k6
Post by eg2k6 » Tue May 08, 2007 4:43 pm
im not using linux, so, i dunno... ill check it
zuegs
Post by zuegs » Tue May 08, 2007 7:26 pm
check blenders console output :wink: perhaps you forgot to setup the "indigowrapper.conf" file :wink:
mrCarnivore
Post by mrCarnivore » Tue May 08, 2007 7:45 pm
I noticed in blendigo 0.7t7 (I think it is in other versions, too) that the aperture value gets resettet everytime you close the skript window or click ctrl-z in blender (which closes the skript window). So the value is not saved...
zuegs
Post by zuegs » Tue May 08, 2007 8:08 pm
@mrCarnivore:
Thx for info, will check that asap...
zsouthboy
Post by zsouthboy » Thu May 10, 2007 3:08 am
Dear zuegs:
thank you.
(I don't think I ever just took a step back to see how far we've come!)
So I'm just saying that I (and we all) appreciate all of the hard work you have done! :)
Man, remember back in the .5 days?
Fiddling with internal blender material settings - bleh.
So, seriously, thank you and everyone.
zuegs
Post by zuegs » Thu May 10, 2007 4:53 am
Hi zsouthboy,
THX :D VERY :D MUCH :!:
It's the great support from the comunity that pushs me forward :D
So I like to forward a big thank to everyone that codes, uses and comments Blendigo!
Anthony
Post by Anthony » Thu May 10, 2007 4:16 pm
Why is there no separate thread for Blendigo 0.8?
Post by Zom-B » Thu May 10, 2007 5:30 pm
Anthony wrote:Why is there no separate thread for Blendigo 0.8?
:arrow: link
