M2I 0.612
Kosmokrator
Post by Kosmokrator » Mon Jul 31, 2006 12:02 pm
the update is....? the read me only? :shock:
:lol:
u3dreal
Re: M2I 0.611
Post by u3dreal » Mon Jul 31, 2006 12:12 pm
u3dreal wrote:Hey all,
Ok so here is the latest Exporter for 3D Max.. :D
Make sure you read the "Readme First" carefully to get all features. :!: :!: :idea:
Get it here !
cheers
u3dreal ;)
Here :D
u3dreal ;)
Kosmokrator
Post by Kosmokrator » Mon Jul 31, 2006 8:58 pm
ok i have done the sharing to slaves but the strange error msg
"--no ""+"" function for ok" its still there!i think this an exporter bug man.....what do u think?
u3dreal
Post by u3dreal » Mon Jul 31, 2006 9:03 pm
Do you use the new exporter...?? 0.611
Cause i tested it and everything works fine... with 3 PCs....
Start and Stop of slaves directly from 3d Max.. :)
Could you be a little more precise on when it happens...?
Or make a scenefile with the bug ?
cheers
u3dreal ;)
Kosmokrator
Post by Kosmokrator » Mon Jul 31, 2006 9:10 pm
ok i wiil test now the new exporter.....wait...and thnx!
Kosmokrator
Post by Kosmokrator » Mon Jul 31, 2006 9:46 pm
:evil: now render starts but only on master...i take this error window...
maybe some network configuration dont let me see the slave? damn!
u3dreal
Post by u3dreal » Mon Jul 31, 2006 10:23 pm
Why damn !! :evil:
It's working .... :D come on ...
Ok now for the network...
are you sure that the folder indigo on the slaves is a networkshare ??
Cause access denied.. .. so you can't copy the files there..
and plz post the indigorunslaves.bat ... maybe there is something wrong there.--
cheers
u3dreal ;)
Kosmokrator
Post by Kosmokrator » Mon Jul 31, 2006 10:33 pm
the drive on slave (i use 1 slave for the moment...) i have set full acces
what files u mean to copy manual?
here is the .bat
@ECHO OFF
Echo IndigoRunSlaves...
REM Remove REM to enable copy of bat file to Slaves.....
copy C:\Indigo\IndigoNetSlave.bat \\mk-sz8sklt39idi\Indigo
REM copy C:\Indigo\IndigoNetSlave.bat \\Lisa\Indigo
REM copy C:\Indigo\IndigoNetSlave.bat \\Homer\Indigo
REM Remove REM and Exchange Simpsons Names with Slaves Names
REM In this case LISA,BART and HOMER are NetSlaves..;)............
psexec \\mk-sz8sklt39idi -u mk-sz8sklt39idi\Indigo -p Indigo -i C:\Indigo\SlaveRun.bat
REM psexec \\BART -u BART\Indigo -p Indigo -i C:\Indigo\SlaveRun.bat
REM psexec \\HOMER -u HOMER\Indigo -p Indigo -i C:\Indigo\SlaveRun.bat
REM NOTE: psexec will not run on Win XP Home as far as i know
REM If you get it to work plz mail me ....see readme
EXIT
u3dreal
Post by u3dreal » Mon Jul 31, 2006 10:50 pm
Ok this seems OK ...
check if the IndigoNetSlave.bat gets copied ... delete the old one in slave dir.
if this works run the IndigoNetSlave.bat manually on slave...
If this works we can go on ..
cheers
u3dreal ;)
Kosmokrator
Post by Kosmokrator » Tue Aug 01, 2006 12:00 am
ok i have run manually the bat file in slave computer and....indigo found the textures,xml file ,exr files on master but... eventualy show this erron and stop.... :evil: damn network!
Kosmokrator
Post by Kosmokrator » Tue Aug 01, 2006 12:38 am
ok now works fine!!!its my fault! but i have an other problem now....when tha indigo try to save the png image i take this in console..
and the file .png is black,nothing saved...!!!
u3dreal
Post by u3dreal » Tue Aug 01, 2006 12:43 am
This seems to be a network problem ...
make sure the folder //mk3dtech-2s48u0/indigo/ is networkshared
and the folder indigo/renders exists..
cheers
but so far the exporter seems to work ... great ... congrats..
u3dreal ;)
Kosmokrator
Post by Kosmokrator » Tue Aug 01, 2006 12:50 am
yyyeeappp!now all works fine...lets make some tests now how realy helps the coop rendering.. :wink:
thnx a lot for help!!!
u3dreal
Post by u3dreal » Tue Aug 01, 2006 2:22 am
Cool i knew it works... :)
cheers
u3dreal ;)
Kosmokrator
Post by Kosmokrator » Tue Aug 01, 2006 2:26 am
how exactly works indigo coop rendering?the calculations of slaves transfered to master and added to master calculations?
or the image transfered and "Mixed" with others to make a beeter result?
