Green living
- Borgleader
Re: Green living
Hi all!
..guys, I really appreciate how you supported me with all your encouraging comments and critiques.
This is going to be a towards-final image. I exported the scene correctly, so now I have igs, igi and all I need to resume the render later on
I added some minor details here and there, and adjusted some materials I didn't like too much. Not that now I am satisfied with the result but this is surely a progress.
Now rendering at 3200pxls resolution, 4 light layers (supersample 1): night shot is very slow to compute, so I expect biblical times. Now something to share with you.
Thank you all.
Thank you all.
- wip9_small_2.jpg (1.04 MiB) Viewed 6431 times
Re: Green living
This one is gorgeous, I want to live there! Looks like setting the supersample to 1 makes the edges of objects look sharp just like Vray renderings. Very beautiful!
Re: Green living
Supersample=1 doesn't make the edges look crispier. Sharpen filter does.
Thank you for your feedback Jeff.
Re: Green living
Pibuz,
Very well done! Jeff already said that he wanted to live there but what's even more important and really brings life into the scene is that it conveys the feeling that someone actually does live there.
I am sure that all the "little things" took quite a bit of time and it really shows.
- PureSpider
Re: Green living
Great and cozy image, Pibuz! Actually, as always
Maybe just small imperfections like a fly (or two
) on the wall and a piece of thrown paper on the floor and it will get even more life-like.
- Borgleader
Re: Green living
This is the part where you tell us this is a photo of your apartment (after you spent 8 hours cleaning up) and I believe you
No seriously this is AWESOME, were it 1280x800 id use it as my laptop wallpaper (honest!)
Re: Green living
Thank you guys: your comments are flattering
..One thing really bothers me now: I tried to resume the render after having stopped it (it cooked a night) and Indigo wasn't able to handle the scene.
Same scene, resumed; RAM consumption: DIFFERENT!
So I'm NOT able to continue rendering this scene.
I would suggest the developers to fix this big thing, which is actually uncomprehensible from my point of view, and which can really cause lots of problems when resuming a render.
Re: Green living
So far it's stunning. 5/5!
Re: Green living
Very nice pibuz ! Great work ! But i think there is something out of scale...or my eyes lie.
- Borgleader
Re: Green living
How much ram do you have?Pibuz wrote:Thank you guys: your comments are flattering![]()
Same scene, resumed; RAM consumption: DIFFERENT!.
- Polinalkrimizei
Re: Green living
Purely awesome.
What happens when I see your render: I don't see it as a render. Not because it is the most photorealistic one I've ever seen, but because it just works. All I see is a really cool apartment that has that special something.
Re: Green living
I have 4GB installed.Borgleader wrote: How much ram do you have?
But that is not the point Borg: when I render my scene exporting directly from SketchUp all goes fine, the scene is rendered at a certain resolution. For final images I usually take the resolution to the highest supported level, in this case I could reach 3200pxls of width (supersample 1) and the render started with no problems. The render cooked for a night encountering no problems. In the morning I simply stopped the calculation, saving igi and stuff. The following night I wanted to resume the render and I got the classic message you get when there is no more RAM available.
That is something wrong. I suppose there is some kind of problem. But I think one should be ALWAYS able to resume a render he previously launched on the same machine. Otherwise, if you cannot render at a certain resolution you shouldn't be allowed to launch the render at THAT resolution, discovering later that you cannot resume the calculation.
From a very naive point of view, I cannot understand why the RAM consumption should be different for the same image, indeed. But I'm not a programmer, there could be some kind of tricky code.
Polinalkrimizei
Thank you very much: in this image I wanted to reproduce an everyday scene, simple and plain.
Nothing too fancy and nothing too architectural: something everyone could experience or achieve. Thank you very much.
dcm
Thank you for having commented this. Perhaps there is actually something out of scale. Now tell me what is it.
tomasbird
Thank you my friend. Post your tests as well! Seeing something new is always a pleasure, if it could help someone else!
- Borgleader
Re: Green living
Ah well, I'll re-iterate my offer if you ever need a rig to render your scene because it takes a while, mines not doing much these days.
In the mean time you might want to send your issue in the bugs/request forum so that the mods are officially aware of it.
Oh and keep up the good work
