Blendigo 2.0.10
- aleksandera
Re: Blendigo 2.0.10
Thanks for that answer
- aleksandera
Re: Blendigo 2.0.10
Hm, weard. I have no texture on this face, but some quads
seam to apear here in two diferent colours....
What is wrong???
What is wrong???
- aleksandera
Re: Blendigo 2.0.10
Anybody?
Re: Blendigo 2.0.10
looks like the old self intersection issue. which indigo version do you use? 2.0 stable?
whats the scale(in meters) of that... dude... is it close to real world scale? it should be!
awesome.... thing... btw
Re: Blendigo 2.0.10
Maybe try to remove doubles, it looks like a subsurf problem too...
Maybe subsurf and subdivision smoothing are sometines in conflict, try withont subdivision smoothing or with a lower value to subsurf...
Maybe try to reactive subsurf on your mesh by selecting solid then smooth...
Can you share a screenshot of your wire?
Re: Blendigo 2.0.10
I try to exprt my first animation, maybe I do something wrong...
I remember an old version of blendigo with a path to save images? I'm wrong?
Sorry: output path doesn't work
- Capture.PNG (56.47 KiB) Viewed 4940 times
Re: Blendigo 2.0.10
Oops... Animation, i completly forgot about animation. give me some time to fix itJambert wrote:I try to exprt my first animation, maybe I do something wrong...
Check normals, dude!
Re: Blendigo 2.0.10
Yes you're back, hope you get nice holydaysSmartDen wrote:Oops... Animation, i completly forgot about animation. give me some time to fix itJambert wrote:I try to exprt my first animation, maybe I do something wrong...
Sorry: output path doesn't workand thanks for the hint
Re: Blendigo 2.0.10
Smartden, do you know why Alt-D instances in blender aren't interpreted by indigo as real instances?
Re: Blendigo 2.0.10
Jambert wrote:Great I'm not alone...Godzilla wrote:I have the same problem when I try to preview a material, not that big of a deal to me though.Jambert wrote:I up my problem, no issu at all...
Any news?
Re: Blendigo 2.0.10
hmm... it works for me. can you give an example?Jambert wrote:Smartden, do you know why Alt-D instances in blender aren't interpreted by indigo as real instances?
Re: Blendigo 2.0.10
SmartDen wrote:hmm... it works for me. can you give an example?Jambert wrote:Smartden, do you know why Alt-D instances in blender aren't interpreted by indigo as real instances?
I do it now
Re: Blendigo 2.0.10
I've made a test with Modifier Array. Meshs are created when blendigo export and igs file is realy big. Igs file should be egale, no?
- instance 2.JPG (25.95 KiB) Viewed 4758 times
- instance.JPG (33.83 KiB) Viewed 4756 times
- Instance test.rar
- (25.95 KiB) Downloaded 232 times
Re: Blendigo 2.0.10
I made new test with Alt-D insatance and I think it works
Sorry, I don't realy understand why it didn't work before? I'm losed, array modifier shoud generate instances?
Re: Blendigo 2.0.10
Array modifier generates one meshJambert wrote:I'm losed, array modifier shoud generate instances?
