Indigo Binary Mesh (.igmesh) format with source code.
Re: Indigo Binary Mesh (.igmesh) format with source code.
I wrote an igmesh reader and writer in python - see attached.
I tested by loading the mesh.igmesh in testscenes/ and writing it back.
The written back file was identical to the original.
After loading an object the following member vars are int:
magic_number, format_version, num_uv_mappings, num_used_materials, num_vert_positions, num_vert_normals, num_uv_pairs, num_triangles
The following member vars are lists of 3-tuples: vert_positions, vert_normals
The following is a list of 2-tuples: uv_pairs
The following is a dict: uv_set_expositions
the dict format is { index: name }
The following is a list of dicts: triangles
the dicts are of the format
'vertex_indices': <list of ints>,
'uv_indices': <list of ints>,
'tri_mat_index': int
I've no idea how it will perform with larger data sets yet.
- igmesh.zip
- (2.06 KiB) Downloaded 950 times
Don't know where the bottleneck is yet, but here's a preliminary benchmark:
[EF 2009-09-05 22:09:08] Indigo export started...
<igmesh
Magic Number: 5456751
Format Version: 1
Num UV Mappings: 0
Num Used Materials: 1
Used Materials: ['clay']
Num UV Set Expositions: 0
UV Set Expositions: {}
Num vert positions: 495794
Vert positions: <list length 495794>
Num Vert Normals: 0
Vert Normals: <list length 0>
Num UV Pairs: 0
UV Pairs: <list length 0>
Num Triangles: 991232
Triangles: <list length 991232>
Data size: 33704068 bytes
[EF 2009-09-05 22:09:24] ...finished. Export took 15.297000 seconds
Suv or Nick,
Can you explain the multi-uv ordering? I'm coming across the same problems.
Hi dougal, actually I just checked in a python igmesh reader/writer to the blendigo src, if you want to have a look at that.
The UV ordering inteleaves the uv sets/layers
So if there are M uv coords per layer, and N uv layers,
and uv_i_j is the i-th uv coordinate in the j-th set/layer, then the UVs area laid out like so:
uv_0_0
uv_0_1
uv_0_N
uv_1_0
uv_1_1
uv_1_N
uv_2_0
uv_M_N
uv_0_0
uv_0_1
uv_0_N
uv_1_0
uv_1_1
uv_1_N
uv_2_0
uv_M_N
Oh, right. That will be interesting to compareOnoSendai wrote:Hi dougal, actually I just checked in a python igmesh reader/writer to the blendigo src, if you want to have a look at that.
I'm not sure if I know where you've 'checked-in' to exactly ... please PM or email me details.
The rest makes sense.
Cheers,
Doug.
attached.
Ignore class OldIndigoMesh, use INdigoMesh.
I used the python 'array' module because it's faster.
Stupid scripting languages.
- indigo_mesh.zip
- (1.54 KiB) Downloaded 1031 times
So, this Python IGMESH code is guarenteed to work? Or has it been modified/fixed since you attached it here, Ono?OnoSendai wrote:attached.
I don't know Python but it looks fairly similar to Ruby. Any advice on porting this code to Ruby?
SHould work for Python, yeah, but I think it uses quite python-specific techniques.
Nick's published igmesh code produces erroneous files on 64bit (linux only?) systems because of the Long data types used. (Should be ints).OnoSendai wrote:SHould work for Python, yeah, but I think it uses quite python-specific techniques.
Look in blendigo source since 2.2.8 for igmesh code that works more reliably.
Oh dear.. sorry about that
Thanks doug, will do!
Yeah, but it looks like the process of packing the data into binary format is the same as Ruby. That's my main concern.OnoSendai wrote:SHould work for Python, yeah, but I think it uses quite python-specific techniques.
BTW, what's the difference between num_uv_mappings and num_uv_expositions? Will this number always be the same?
Uv sets are the number of uv layers.
uv set expositions are naming of particular layers, of which there may be many per layer.
At the risk of asking the obvious...
in Indigo 4 compressed .igmesh files were introduced, is there any documentation of the compressed format or how to unpack it?
