Maxigo 1.15.7-Test1a [update-09.07.08]
Hi tacos, what does tacos mean in Italy? because here in México it means a very tasty traditional food.
The answer is yes you can render furry carpets and grass too, you have to use maxigo diplacement and UVW map applied to your object, in maxigo's displacement modifier you have to load a displacement map and play around with the properties there and in the scale of the UVW map modifier either.
I will post some images later.
Ciao (hasta luego).
-Rafaello
Ciao (hasta luego).
-Rafaello
Here are the images, I don't have a good displacement maps, so grab a good ones and apply a SSS material to grass.
- A quick grass render
- Pasto.png (127.68 KiB) Viewed 8224 times
- Furry carpet
- Otra alfombra.png (137.57 KiB) Viewed 8225 times
- A soft carpet
- Alfombra peluda.png (135.08 KiB) Viewed 8222 times
- The base mesh for all the renders
- 3ds Max 2009.png (64.88 KiB) Viewed 8221 times
Thanks, This is a test for an interior scene of how is going to look the living room of my future house (which exists only in paper
I used the maxigo's displacement in the carpet.
- Rafaello
- Rafaello
- Prueba de sala 7 horas 48 minutos con maxigo displacement, pathtrace y bidirectional
- CasaMoIIndigo.png (881.25 KiB) Viewed 8152 times
Hello tacos, these are the settings for displacement and UVW mapping and the carpet is a 2m X 2m X 0.01m box with 20 X 20 X 2 subdivision.
- Displacement map
- carpet-displace.jpg (795.59 KiB) Viewed 8060 times
- Settings
- Dibujo1.jpg (25.79 KiB) Viewed 8045 times
- Settings
- Dibujo.jpg (20.53 KiB) Viewed 8048 times
