- aleksandera
- aleksandera
- PureSpider
- Borgleader
- Phr0stByte
Kram1032:
NOT! Its only a little corner of a window - not a whole window. I would be impressed if there were blinds between the two pains of glass.
No, seriously I am joking - this is awesome stuff!!!
aleksandera's chic is also pretty damn cool - just how I like 'em: wet and naked. The bald thing must be an acquired taste...
- aleksandera
CTZn:
Modeled in ZB. Displacement maps generated in ZB and they dont work in Indigo. There is only one high poly mash and two instances. The chick is
pure polimodeling.
Phr0stByte:
There is some hair, but this is only a region render.
Caronte:
Nice model. Just wonder, how much can you earn with stuff like this?
Chears!
pure polimodeling.
Phr0stByte:
Caronte:
Chears!
I would not say that, just looks like they need a negative offset. If you have a chance, add and/or edit the <c> xml tag in displacement_map, like so:CTZn:
<displacement_map>
<uv_set>default</uv_set>
<path>textures\MAT_DISP-pCube2.tga</path>
<exponent>1</exponent>
<b>0.5</b>
<c>0.5</c>
</displacement_map> Also ZBrush outputs the depth of the displacement map, it's a float value wich should be used as the offset. I've read that in a ZBrush to Maya workflow pdf IIRC.
It was a time where I could have been a modeling competitor...
<nudity coming here too>
</nudity obviously wip, focused on the top of body> For the short story, it is initially based on the joan of arc tutorial; I brought it further. Yes, I was forced to use 3dsMax
