dcm
Post by dcm » Tue Jul 10, 2012 9:49 am
thats so mothaphukin cool :shock:
solarray
Post by solarray » Thu Jul 12, 2012 9:55 am
Thank you, nice to know that Im not the only one :)
Here another object:
Fitting 90 degree
Post by suvakas » Wed Jul 18, 2012 6:16 am
Playing with new animation retime feature in Max 2013 :) Rendered with Indigo.
http://www.youtube.com/watch?v=I9PgdY6DAIE
Post by lycium » Wed Jul 18, 2012 7:26 am
Sweet abstract, but I gotta beg you again to use radial+sharp filters! ;)
cotty
Post by cotty » Mon Jul 23, 2012 6:43 am
(Model from alvis)
subpixel
Post by subpixel » Mon Jul 23, 2012 5:26 pm
Hello,
Here's a first test of implemented normal maps in IndigoMax. Effect is a bit too subtle and needs some more investigation.
Cheers,
Troll Cleric from MAX scenes package with normal map
Post by CTZn » Thu Jul 26, 2012 4:48 pm
Canyons !
Subdivision and displacement took 1013.7613587519008 s
resulting num quads: 20147200
canyons.pigm
(882 Bytes) Downloaded 262 times
cotty
Post by cotty » Thu Jul 26, 2012 5:37 pm
CTZn wrote:Canyons !
:shock:
A nice "simple render" :wink:
Post by Pibuz » Thu Jul 26, 2012 6:16 pm
Oh God! That's wonderful!
..Always loved displacement :lol:
The colour distribution is shader or there's a base texture? Could you show us the maps, even little, just to have an idea of what your workflow has been :D
ninopiamonte
Post by ninopiamonte » Thu Jul 26, 2012 9:59 pm
Awesome! :o
'T can be a wallpaper with more details.
Post by CTZn » Fri Jul 27, 2012 12:54 am
The beauty Cotty is that the displacement shader is even simpler than the albedo shader: no maps used Pibuz it's all ISL !
The displacement method is basically a noise wich uses itself for it's U and V placement. By the way I should be able to add directional (wind) erosion. The albedo mixes a bit of the displacement (lower is darker) with randomized horizontal layers.
The material is attached above; I applied it on a 1km square plane. The subdivision is view dependent, there's no way my computer can handle more polys, Nino :)
Virtual landscapes are pretty exciting I recon !
Post by OnoSendai » Fri Jul 27, 2012 12:58 am
Super-awesome work CTZn!
It looks like you're using the normal Indigo sun+sky model (as opposed to the full atmospheric scattering simulation), is that correct?
It would be nice to see with the full simulation.
Post by CTZn » Fri Jul 27, 2012 1:05 am
It certainly would look awesome ! I'll do that at some point Nick, meanwhile there is the scene for the courageous rigs; they'll need 8 Gigs equiped, more or less.
canyons.pigs
manypolys
(2.85 KiB) Downloaded 311 times
Post by CTZn » Fri Jul 27, 2012 1:25 am
Oh, and something else I add in mind was to explore the Indigo scattering capabilities to add rocks and boulders at the ground level.
I'll create a thread on virtual landscapes.
Post by OnoSendai » Fri Jul 27, 2012 1:27 am
CTZn wrote:Oh, and something else I add in mind was to explore the Indigo scattering capabilities to add rocks and boulders at the ground level.
Yup, that's what the scattering stuff is for!
I think there are problems with scattering and quads currently, so I don't think it will work currently.
