Indigo Renderer 4 public beta
Originalplan®
Post by Originalplan® » Mon Apr 25, 2016 11:41 pm
Originalplan® wrote:@contegufo Nice find!
So testin the V4 for about two weeks in. I didn't find any new & critical Bugs on my part.
Maybe this was a bit early :)
Found a new BUG : GPU render does not support rendering Alpha setups. Renders the whole scene alpha.
Bidir & els working fine.
Plus found a new easter egg: Hold down alt + grab the Indigo App frame from the bottom and resize it! :)
Post by Oscar J » Mon Apr 25, 2016 11:49 pm
Yup, alpha rendering isn't done yet. Looking forward to that :)
Originalplan®
Post by Originalplan® » Tue Apr 26, 2016 2:02 am
Exporter related BUG : OSX Cindigo latest v3 build.
So Cindigo does not like when exporting Cloned objects that have Random effector specially in the Rotation segment. No workaround simply this error message. It works when i delete the rotation effector.
Cindigo Bug
contegufo
Post by contegufo » Tue Apr 26, 2016 11:26 pm
Hi
Indigo4, CPU Rendering unfortunately!
Glass + FSSS.
Post by Oscar J » Wed Apr 27, 2016 1:59 am
Nice :)
FakeShamus
Post by FakeShamus » Wed Apr 27, 2016 2:27 am
any word from dev's about this igi resume issue? it's really messing with my workflow.
also, not sure if this is a bug or just outdated, but I tried merging 2 igi's from terminal with the --merge_igi command and a file list and I get an error that the igi's can't be read. this happens with v 4 and 3.8 both.
Failed to open file 'blah-blah-myfile.igi' for reading
Originalplan®
Post by Originalplan® » Wed Apr 27, 2016 4:05 am
FakeShamus wrote: I tried merging 2 igi's from terminal with the --merge_igi command
Wow!!! That's a thing!? Merging IGI's via Terminal?? O _ O
Post by pixie » Wed Apr 27, 2016 4:22 am
Only for the brave! xD
FakeShamus
Post by FakeShamus » Wed Apr 27, 2016 4:35 am
yeah, at least it was a thing... maybe the igi spec changed?
used to be the command was:
./IndigoConsole --merge_igi listoffilestomerge.txt outputfile.igi
fourzeronine
Post by fourzeronine » Wed Apr 27, 2016 5:53 pm
wow this is incredible, my scenes is going from around 1m/s to over 10m/s with my gpus. If I own v3 is there an upgrade I can purchase or do I have to purchase a full v4 license?
Post by Oscar J » Wed Apr 27, 2016 6:27 pm
Originalplan®
Post by Originalplan® » Wed Apr 27, 2016 8:22 pm
fourzeronine wrote:wow this is incredible, my scenes is going from around 1m/s to over 10m/s with my gpus.
Welcome to the Indigo 4 fan club. :D
Post by OnoSendai » Thu Apr 28, 2016 3:20 am
Have updated all download links in the first post to v4.0.36.
Changelog:
4.0.36
* Fixed problem with measured BRDF not being transferred during network rendering.
* GPU PT: Fixed crash on arch glass.
* GPU PT: fixed displacement shaders, were giving compile errors.
* GPU PT: Total used constant memory should now be < 64KB, which is the min guaranteed supported amount.
* Optimised and improved Indigo's phong, coating etc.. materials
4.0.35
* Much faster rendering with motion blurred objects in most cases.
* Identifying material in error message for OpenCL processing failure.
* Not writing some XML elements if they have the default values - in <mesh>, <model2> etc..
* Accepting <uid> as well as <material_uid> in model2 material list. (saves space)
4.0.34
* GPU PT: Will show error dialog to users now on GPU path tracing init failure.
* GPU PT: Fixed crash on Linux.
* GPU PT: Improved handling of base emission for GPU, now handles all spectra types.
The test scenes (car and bedroom) should now work on all OpenCL 1.1+ compliant devices. Just don't expect it to run fast on old GPUs :)
Originalplan®
Post by Originalplan® » Thu Apr 28, 2016 4:17 am
Fast SSS bug?? v.4.0.36
Not working on GPU.
Mostly problem cause is tabulated data.Wasn't a problem in earlier ver.
Post by Oscar J » Thu Apr 28, 2016 4:21 am
Works for me. Strange!
