M2I 0.612
F3LIC3 ... you have same problem ....??F3LIC3 wrote:Here is the IndigoRun.bat:
http://web.utanet.at/klavier6/Files/IndigoRun.bat
I hope we can fix this little problem, but anyway your exporter is awesome!!!
Exactly what is happening... does the master and the slave on the master start ... do the slaves strart ..?
I need exact facts... i can't help you fix anything if i just get a
it doesn' t work or what am i doing wrong .. if i not even know
what you are doing ... sorry this had to be said... cause sometimes ppl
think i can actually watch what they are doing...
Ok do some investigation on what works and what not ...then let me
know... best thing is to prepare a small test scene that shows the bug
... so it will be way faster for me to find the problem.
Ok I'll check the netrender ..that maybe i broke some when i did all this new stuff..
already have some suspicion...
cheers
u3dreal
Done ...psor wrote:Thanx!![]()
edit: Erm, ...... a lil wish. Could you please make it possible
to save the Rendersettings too? You know Large Mutation, Max Mutation Size, ... etc.
And just a small glitch, if bidirectional is enabled you can
blend Russian Roulette out ...
btw. As far as Nick mentioned, your default settings are a bit off,
especialy the low settings for Russian Roulette. So you should use
Nicks default settings as M2I default. Like this ...:
Large Mutation: 0.4
Max Mutation Size 0.02
Russian Roulette: 0.7
cheers
u3dreal
As far as i know this is not possible ... as the project/project1 dirpsor wrote: And one more thing, ... if I want to render directly out of 3dsmax
I have to save the scenefile into indigo root and not the scene dir,
hmm ... not really what I need.![]()
I would also like to see an
option like the "Save Image as" option for the texture directory.
I don't want to have the textures for all projects in one folder.
Like this ...:
Path to Textures: projects/project1
... this would be translated into: textures/projects/project1
psor
now is the indigoworld... so you will have to create a subfolder
named textures and if you use procedurals a subfolder named
textures/procedurals...
So i fixed this ... i actually forgot to pass the scenepath ..
It should work now...
If i get qualified feedback ... it's a pleasure to fix things..psor wrote: Well, ... no pressure, but I would like to see it if you have the time
to get something like this working.![]()
psor
cause it's so easy then ...
cheers
u3dreal
- Kosmokrator
about my problem?how can set up the coop rendering?the readme file is confusing me in some points....
make sure you have "easy filesharing" disabled .. !!!!!!
In Indigo Folder go to Extra/Options/view--enable easy filesharing (x)
DISABLE this one !!.....this will enabled netlogon with name/pass.
where is this options "easy file sharing"?Im on win xp pro sp2! 3ds max 7
please make a analytical tutorial for this...
thnx alot for help...
OK ...
its here ..
In the top menue ... !!! of your folder ...! Its actually in every folder
and it can be set in every folder and will have effect on every folder.
I know this is a bit too deep for some users...
But we will solve it ...
Of course if you use greek letters it will be hard for me to tell
Its the second one from the right after the "?" ...
Try to find it....
cheers
u3dreal
its here ..
Try to find it....
cheers
u3dreal
- Kosmokrator
OK there seems to be a difference here... i was only guessing
cause i got the german version... one sec...
Actually i think you are the first to set up cooperative render..
Congrats !!! but this means also some difficulties..
No worries we are near ... and i also have a updated version of the
exporter ready...
cheers
u3dreal
exporter ready...
cheers
u3dreal
- Kosmokrator
updated version?thats cool man!ok im the first of coop rendering?
well i do netrendering with fRender and maxwell its a must for big and complex projects...thanx for help anyway,have patience please..
- Kosmokrator
- Kosmokrator
ok i will create tha acount to all slaves tomorow and i send u feedback i cant today its deep night here...thnx a lot for ur help!u r amazing man!keep tha good work i hope to found a solution eventualy
