[REQ] Backface-Culling!
Re: [REQ] Backface-Culling!
Post by zeitmeister » Wed Dec 16, 2009 10:35 pm
Yeah!
cucus
Post by cucus » Fri Dec 07, 2012 3:00 am
Hi !
Sorry to use this old topic but someone know if this feature is implemented ?
Cuucus
Post by Zom-B » Fri Dec 07, 2012 3:47 am
It isn't! Never thought it be that useful...
Only thing somehow related is Indigo's SubDiv, that has a ViewDependent setting where you can set a Pixel & Curvature Threshold, also meshes outside the camera view also don't get subdivided :)
galinette
Post by galinette » Fri Dec 07, 2012 4:02 am
Depends which feature, but the clipping planes to which the discussion has evolved have been implemented
Etienne
Eclat-Digital Research
http://www.eclat-digital.com
cucus
Post by cucus » Tue Dec 11, 2012 11:43 pm
galinette wrote:Depends which feature, but the clipping planes to which the discussion has evolved have been implemented
Yep, this one.
how can I use it, because I found nothing in the documentation.
Thx,
Cucus
Post by Zom-B » Tue Dec 11, 2012 11:47 pm
cucus wrote:Yep, this one.
How should we know without the info what Exporter you use :roll:
Afaik its not directly accessible from Indigos GUI atm...
cucus
Post by cucus » Wed Dec 12, 2012 12:01 am
Oops, sorry !
I use 3ds Max 2012 and Maxigo v3.0.7.
Btw, which version of Ingdigo has the clipping plane ?
Post by Zom-B » Wed Dec 12, 2012 12:35 am
Its in since Indigo 3.4.3.
Your old Maxigo is discontinued, and was rewrite from scratch, breaking any compatibility to the old version:
http://www.indigorenderer.com/forum/vie ... =9&t=11889
I have no idea how development is handled there, since it isn't a official Exporter anymore :?
The Official new Exporter from Subpixel is still in (slow) development:
http://www.indigorenderer.com/forum/vie ... =9&t=11368
Both Exporters don't support the clipping planes and both aren't compatible to your old scene & material setup!
cucus
Post by cucus » Wed Dec 12, 2012 1:18 am
Thanks for you clarification.
So, if I want to use this feature, what is the procedure ?
Cucus
Post by Zom-B » Wed Dec 12, 2012 1:53 am
cucus wrote:So, if I want to use this feature, what is the procedure ?
I think in your situation you need to know how your "Indigo future" will look like first regarding the exporter situation.
there are 4 "kind of" options:
- stay with old Maxigo version but wait for a new Indigo with GUI setup for Section Planes.
That would result in hand editing exported scenes all the time to render them... sucks hard!
- set your bet on the new 3D Max exporter and play the waiting game.
- set your bet on the (unofficial) Maxigo exporter from Suvakas and play the waiting game.
- Change to a 3D app with proper Exporter support
tar_gniK
3D Software: 3ds Max
Post by tar_gniK » Wed Dec 12, 2012 3:34 am
@ Zom-B: Point 4 is sucks more than point 1. Right, so us Max users should change to Blender, Maya, SketchUp, C4D etc, re-build all scenes (even if one was to export to obj or another method - yawn), re-assign materials, not to mention having to get used to a different interface -- all because of inadequate exporter support? That is too much of a sacrifice.
galinette
Post by galinette » Wed Dec 12, 2012 3:54 am
I would add point 5:
- Add manually the section plane in the xml code of the .igs file... That should not be so difficult, even if not super user-friendly...
galinette
Post by galinette » Wed Dec 12, 2012 3:55 am
galinette wrote:I would add point 5:
Notepad++ has a wonderful Indigo exporter that gets never out-of-date, and is fully cross-platform : File>Save As :)
I'm using it all the time...
cucus
Post by cucus » Wed Dec 12, 2012 4:21 am
I like this point, I use it all the time too :).
But for the clipping I don't know what is the name of the attributs.
Can you help me Galinette, pls ?
Cucus
Post by Zom-B » Wed Dec 12, 2012 4:28 am
Section Planes get defined like that:
	<section_plane>
		<uid>8</uid>
		<name></name>
		<point>0 0 0</point>
		<normal>0 1 0</normal>
		<cull_geometry>true</cull_geometry>
	</section_plane>
Point seems to be the positions and normal the rotation, I can be wrong here.
You'll also maybe need to adjust your IGS further to be compatible with newer Indigo versions.
