You are sooooo rightfused wrote:PureSpider will not let me rest anyway until i implemented it
Cindigo Wishlist
- PureSpider
Re: Cindigo Wishlist
sort of got it working. some stuff still to fix and optimize....
- zeitmeister
Maybe an option where you can decide wether these planes are opaque or not would be great?
It's a massive object in the editor window in the current state...
of course you will be able to turn it off
- PureSpider
But when you turn it off, leave the borders of the planes visible maybe?
Great work fused, this looks realy nice!
I also think that maybe the front and back plane could use a 50% reduction in alphazeitmeister wrote:Maybe an option where you can decide wether these planes are opaque or not would be great?
yes, i was going to add that. maybe ill also add a "transparency" option for each plane next to the enable switch.ZomB wrote:I also think that maybe the front and back plane could use a 50% reduction in alpha
no need, im just using c4ds near and far settings, so teh lines are automatically drawn.pSr wrote:But when you turn it off, leave the borders of the planes visible maybe?
- PureSpider
Aha, my suggestionfused wrote:no need, im just using c4ds near and far settings, so teh lines are automatically drawn.pSr wrote:But when you turn it off, leave the borders of the planes visible maybe?
Good boy!
do you want me to work on you requests or not? sounds like 'not'.PureSpider wrote:Good boy!
Hello Fused,
I know 3d-developers are busy these days. I'm just wondering how
difficult it might be to write a fisheye/angular map-exporter for indigo?
Would make a great function and hardly exists today...
Just for the wishlist
Steven
Steven
Multi-Pass
If cindingo is in c4d, is it possible to make layers for passes(multi pass system)?
Other rs engines have such in post effects section.
I'm sorry for my bad English
Re: Multi-Pass
Hi Ilay,Ilay wrote:If cindingo is in c4d, is it possible to make layers for passes(multi pass system)?
how do you mean exactly? Do you want the background alpha and material id modes available as passes?
Hello Yves
Yes and i also think about exr-layers for light layers..
Ok, I will look into thisIlay wrote:Hello Yves
Thanks, it's not so significant. If only you will have free time.fused wrote:Ok, I will look into thisIlay wrote:Hello Yves
