SkIndigo 2.0.8
Re: SkIndigo 2.0.8
Post by neo0. » Sun Jun 28, 2009 2:17 pm
Well I'll be damned.. Looks like I did..
Here's what the ruby console says now
Error: #<Errno::ENOENT: No such file or directory - C:\Users\Eric\AppData\Roaming/Indigo Renderer/default-meshes.igs>
C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/skindigo.rb:427:in `initialize'
C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/skindigo.rb:427:in `new'
C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/skindigo.rb:427:in `export'
C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/skindigo.rb:7336
Nah, I don't have that folder in /roaming.. It must be missing..
Re: SkIndigo 2.0.8
Post by Whaat » Sun Jun 28, 2009 2:25 pm
Neo,
Try opening Indigo and rendering a testscene from the testscene folder. After doing so, then try to Render a scene using SkIndigo.
I suspect that Indigo is not creating the 'Indigo Renderer' path when you install Indigo. It may be only creating the path the first time you render.
Re: SkIndigo 2.0.8
Post by neo0. » Sun Jun 28, 2009 2:28 pm
Well, the test scene worked.. :)
EDIT.. It works now.. F&^% yeah! I want to make babies with Indigo!
My first render with indigo 2.0.8!
yabba dabba doo.jpg (162.46 KiB) Viewed 13103 times
remus
Re: SkIndigo 2.0.8
Post by remus » Mon Jun 29, 2009 9:52 am
Is it possible to do sketcyphysics animations in this version?
remus
Re: SkIndigo 2.0.8
Post by remus » Mon Jun 29, 2009 10:01 am
scrap that, found the 'export sketchy replay' button :D
maepogz
Re: SkIndigo 2.0.8
Post by maepogz » Thu Jul 02, 2009 6:23 pm
i want to buy 1 lifetime license if the countdown goes to 40 hehehehe but is it useable when if i upgrade to core4 cpu? i heard 1 proccessing unit for 1 license hmmm... maybe im stuck to my dual core proccessor. because quad core deliver 400 to 500k speed than to dual core i hope any one can answer me. i love indigo im just watching this site for almost 3 years this is my first comment. sori for my poor english. :D
Re: SkIndigo 2.0.8
Post by Whaat » Fri Jul 03, 2009 2:30 am
maepogz wrote:i want to buy 1 lifetime license if the countdown goes to 40 hehehehe but is it useable when if i upgrade to core4 cpu? i heard 1 proccessing unit for 1 license hmmm... maybe im stuck to my dual core proccessor. because quad core deliver 400 to 500k speed than to dual core i hope any one can answer me. i love indigo im just watching this site for almost 3 years this is my first comment. sori for my poor english. :D
There is no restrictions on the number of processors for a license. However, each computer running Indigo in a network would need a license (either a full license or a node license). You might want to send a private message to benn to confirm this.
Re: SkIndigo 2.0.8
Post by Pibuz » Fri Jul 10, 2009 4:24 am
Hi Whaat: MAJOR issue here.
SkIndigo 2.0.8 doesn't accept any external exponent map. ANY.
What can cause this?
This is REALLY REALLY REALLY annoying...
Re: SkIndigo 2.0.8
Post by Whaat » Fri Jul 10, 2009 5:26 am
Pibuz wrote:Hi Whaat: MAJOR issue here.
Thanks for the report. Are you sure that exponent maps are the ONLY ones that don't work? :) I will make sure to fix this for next release....hopefully released within a week or so.
cpfresh
Re: SkIndigo 2.0.8
Post by cpfresh » Fri Jul 10, 2009 6:21 am
hi whaat, i tested all other material parameters and it does seem to be limited exponent alone. looks like you changed a method name from exp_map to exponent_map and missed it in one spot.
after changing it, it works ok.
exponent in action
Re: SkIndigo 2.0.8
Post by Whaat » Fri Jul 10, 2009 8:21 am
Thanks cpfresh!
cpfresh
Re: SkIndigo 2.0.8
Post by cpfresh » Fri Jul 10, 2009 9:13 am
certainly! :)
Re: SkIndigo 2.0.8
Post by Pibuz » Fri Jul 10, 2009 7:23 pm
..so: will it be fixed in the next release, I suppose :wink:
Happy that it was not so hard to fix :D
At the moment for my professional work I'm back to 1.1.18: my problem is that I have to render a 2500 pixels-wide image, and Indigo crashes at that resolution with two light layers (sky AND sun), though I don't really have the need to separate the two light sources, this time.
So, once again, I ask for an improvement: is possible to make SkIndigo usually export ONE layer for sun and sky, and to specify (in the environment tab) if from time to time one wants to separate the sun and sky layers?
CHF
Re: SkIndigo 2.0.8
Post by CHF » Thu Jul 16, 2009 7:39 am
Hi Whaat,
I switched to your latest exporter, now being unable to export my scene. ruby console gives this output:
"------SkIndigo Export Run------"
"Faces 99916"
"Instances 103"
"Material Meshes 35"
"Component Meshes 4"
"Spheres 0"
Error: #<NoMethodError: undefined method `get_materials' for #<SkindigoMatObserver:0xe641160>>
C:/PROGRA~2/Google/GOOGLE~3/Plugins/skindigo.rb:5025:in `write_mat'
C:/PROGRA~2/Google/GOOGLE~3/Plugins/skindigo.rb:4901:in `export_material'
C:/PROGRA~2/Google/GOOGLE~3/Plugins/skindigo.rb:461:in `export'
C:/PROGRA~2/Google/GOOGLE~3/Plugins/skindigo.rb:461:in `each'
C:/PROGRA~2/Google/GOOGLE~3/Plugins/skindigo.rb:349:in `export_as'
C:/PROGRA~2/Google/GOOGLE~3/Plugins/skindigo.rb:7316
C:/PROGRA~2/Google/GOOGLE~3/Plugins/skindigo.rb:7316:in `call'
I allready cleaned most of my materials, not really being able to find the issue. A fresh scene just works fine.
Thanks in advance
CHF
Ok, seems to be related to a linked igm?! Strange, allways worked so far.
Re: SkIndigo 2.0.8
Post by Whaat » Thu Jul 16, 2009 9:32 am
Hi CHF,
I made some changes and linked IGM material do not work in SkIndigo 2.0.8. I have already fixed them for the next version so just wait a bit for the next version and all will be fine. Maybe try loading the material (instead of linking) in the meantime.
Dale
Users browsing this forum: No registered users and 71 guests
