by fused » Thu Jul 03, 2008 10:43 pm
meinst du polygon objekte mit nem light tag drauf?
by fused » Thu Jul 03, 2008 10:46 pm
wo ich grad drüber nachdenke fäll mir auf dass ich den meshlight export garnich überarbeitet habe nachdem ich von wavefront auf ebedded_2 umgestiegen bin...
da liegt das problem wahrscheinlich...
mrmoose
by mrmoose » Fri Jul 04, 2008 12:50 am
fused wrote:@mrmoose and Camox
when did it crash? does it crash always? c4d version?
It crashes during export. I attach the file, I'm using v10.5
I try with other project and it works
- error.zip
- (17.19 KiB) Downloaded 252 times
Camox
by Camox » Fri Jul 04, 2008 2:55 am
Ja, polygon objekte mit lichttags. Wenn ich sie lösche dann lässt sich die scene problemlos exportieren und rendern. Denke auch das da der fehler ist.
mrmoose
by mrmoose » Fri Jul 04, 2008 3:18 am
Camox wrote:Ja, polygon objekte mit lichttags. Wenn ich sie lösche dann lässt sich die scene problemlos exportieren und rendern. Denke auch das da der fehler ist.
Please, can you speak english so i can understand
Camox
by Camox » Fri Jul 04, 2008 3:33 am
Sry mrmoose, i think the problem is the lighttags. fused work on it.
Test your scene only with backgroundcolor no lighttags.
mrmoose
by mrmoose » Fri Jul 04, 2008 3:38 am
Camox wrote:Sry mrmoose, i think the problem is the lighttags. fused work on it.
I try it, but it crashes again
by fused » Fri Jul 04, 2008 4:06 am
ill have a look at it now.
by fused » Fri Jul 04, 2008 4:23 am
@mrmoose: your scene works fine here.
@camox: lighttags work fine in r9.1 and r10
@both of you:
i remember that someone had similar problems with crashes back in the 1.0.9 days. the solution was to completely delete the cindigo plugin folder (and also all copies of cindigo plugin folder inside the c4d plugin dir) and re-install cindigo there.
Camox
by Camox » Fri Jul 04, 2008 4:52 am
CINDIGO 1.1.5 Beta1 works fine. I have cindigo beta2 new installed but the same problem. One Lighttag and cinema crashes. Background light and sun works !
by fused » Fri Jul 04, 2008 4:57 am
large meshes? new export is a bit ram hungry
edit: i dont have any other explanations left... just hope the next little update works...
Camox
by Camox » Fri Jul 04, 2008 5:01 am
Ok no problem . Thx for your support !
by fused » Fri Jul 04, 2008 5:05 am
one thing you could try... ill send you a new cdl in ~10 minutes. it this works i know where the problem is.
Camox
by Camox » Fri Jul 04, 2008 5:34 am
Same error, i send you a pm with the fault message.
Camox on Fri Jul 04, 2008 9:31 am, edited 1 time in total.
by fused » Fri Jul 04, 2008 5:37 am
found the mistake. will fix it and upload a new version in ~10-15 minutes!
edit: camox, youve got another pm, pls test it!
