Indigo v0.6 test 4
zsouthboy
Post by zsouthboy » Fri Oct 13, 2006 5:19 am
.6 test4 severely washes out a scene, over time, for me.
Last night I started a render, in which the first few minutes looked fine (as in the render looked correct)
Woke up this morning, and it was SEVERELY burned. pure white, except for a few spots that were in shadow.
Nick, are you sure that there isn't a looping bug causing the "burn" effect to happen more than once on the same data? I ask because it seems to get worse over time.
Same scene (which I can email you, if you'd like) in .6 t2 looks fine, as is .5.
.6 t2:
.6 t4
jackei
Post by jackei » Fri Oct 13, 2006 8:18 am
my account was locked=) but now im here!
some work i did in my "no indigo forum" time:
this is a pic i made for a friend who married.
manitwo
Post by manitwo » Fri Oct 13, 2006 8:31 am
just what i expected from you - TOP work jackei !!! :D
eman7613
Post by eman7613 » Fri Oct 13, 2006 8:36 am
holy *#$! i thought that first one was a picture or something, thats amazing.
Yes i know, my spelling sucks
Kachu
Post by Kachu » Fri Oct 13, 2006 9:07 am
Well I know we dont need more compairisons but I found this intresting
6.4 on the Left and 5.7 on the right
It shows that in roughly the same amount of time 5.7 is doing more mutations but The images look very simlar. See the inverted diffrence between them.
Here are the final renders to compair at full resolution
5-7
6-4
Both were with all the same settings on one thread. Intrestingly enough 6.4 used 1/2 - 1/3 the ram and less CPU %
Here are my system specs
P4 2.4 ghz Ht 800 FSB
512 ram (Had plenty remaining with both renders running)
ATI 9600 pro 128
7200 16mb buffer HD
manitwo
Post by manitwo » Fri Oct 13, 2006 9:23 am
:shock: :shock: :shock: :shock: :shock: :shock:
WOW !
i wanted to do similar tests - but failed. How did you do that?
I think, with a bit pimping, this scene is better than the maxwell one.
Kosmokrator
Post by Kosmokrator » Fri Oct 13, 2006 9:32 am
yes its impresive but the main part of all this story is how righr and how acuarate is this result based on physics data ??? i think very few can answer sure....i make just a thought....i love indigo... :wink: :)
Users browsing this forum: Google [Bot] and 61 guests
