Indigo v1.0.9 for Linux Build 2
Grimm
Post by Grimm » Sun Apr 13, 2008 9:34 pm
Hey jur,
9.46 appears to have worked better, thanks!! :) Indigo didn't crash, but the log output stopped being updated at about 1 hour, 7 min into the render. I could still see the image update (flicker) though so it was still working and it quit normally. The only thing I'm not sure about is if the image is still being written to disk.
Grimm
delic
Post by delic » Tue Apr 15, 2008 8:30 pm
I have no scrollbars in linux GUI.
It's not really a pb since we can see the rendered pic in render dir.
But why then use GUI for big images ?
joegiampaoli
Post by joegiampaoli » Tue Apr 15, 2008 9:47 pm
I never use GUI for big images or scenes, mostly as a preview for first minutes of render, when I see everything looks fine, then I stop it and go console.
Joe Giampaoli
My Indigo Gallery
Isigrim
Post by Isigrim » Sat Apr 19, 2008 3:37 am
For all those using Ubuntu Hardy 64bit with the wxGTK problem.
This is easily solved by a simple
sudo apt-get install python-wxgtk2.8
At least this is what helped me.
Thanks for the New Version!
indigo keeps getting better and better
shul
fedora core 8 and python-wxgtk
Post by shul » Sun Apr 20, 2008 10:14 pm
I am using fedora core 8, and can't find python-wxgtk rpm; anyone knows where it is?
thanks,
shul
jurasek
Post by jurasek » Mon Apr 21, 2008 12:20 am
shul
Post by shul » Mon Apr 21, 2008 9:20 am
Thanks :-) but I was looking for FC8 rpm, I saw the source build option
SmartDen
Post by SmartDen » Wed Apr 30, 2008 11:31 am
i can't open any scene with indigo. i get "Illegal Instruction" error if i select "File->Open Indigo Scene" or i press "Alt-O". I have installed libwx and all other stuff. My system is Ububtu Hardy. Have anybody same problem?
Check normals, dude!
joegiampaoli
Post by joegiampaoli » Sun May 04, 2008 8:09 am
SmartDen wrote::(
Nope, not here, but I have Feisty, maybe next week I will upgrade finally to latest ubuntu, I'll let you know.
Joe Giampaoli
My Indigo Gallery
Phr0stByte
Post by Phr0stByte » Sun May 04, 2008 9:08 am
SmartDen
I am on hardy, and it seems to work fine.... Not sure what the problems you are having are, but if you have any questions on lib versions or whatever, just give a shout.
Post by pixie » Sun May 04, 2008 10:47 am
It goes around 50k above my WindowsXP 32bit samples/s 220->270k
(Diffuse_Transmiter test)
sk2k
Post by sk2k » Tue May 06, 2008 2:08 am
it's working for me. Ubunutu 8.04, 32bit, GUI and console version.
MfG
sk2k
tobak30
Post by tobak30 » Tue May 06, 2008 3:18 am
"/home/kjell/Indigo/IndigoWrapper.sh" &
./indigo: error while loading shared libraries: libwx_gtk2u_aui-2.8.so.0: cannot open shared object file: No such file or directory
What does this mean? dunno what it is. I am sitting with a 64 bit linux ubuntu 7.10
joegiampaoli
Post by joegiampaoli » Wed May 07, 2008 8:53 pm
joegiampaoli wrote:
SmartDen wrote::(
Ok SmartDen I upgraded and no problems with Hardy. Does this happen with any scene?
BTW anyone with Hardy has anny tips on fixing audio, specially with two soundcards which I both use, I get the login window drums but after that none of the users have system sounds, although they can play music and such, but seems like something with pulseaudio and gnome....
Joe Giampaoli
My Indigo Gallery
Phr0stByte
Post by Phr0stByte » Wed May 07, 2008 11:02 pm
joegiampaoli
What sound system are you using? I have seen this issue with ALSA and OSS - I prefer to use ESD (eSound). New in Hardy though, is PulseAudio. PulseAudio provides a sound system for applications to hook into. It allows the volume of individual applications to be controlled, mixed into other sound devices, and with a little work, even played out of Bluetooth headphones. 8.04 improves upon this by enabling the sound server for most, if not all, applications.
