Kosmokrator
by Kosmokrator » Wed Nov 28, 2007 9:27 am
yes suv u have right...
<scenedata>
<material>
<name>prev_mat</name>
<phong>
<diffuse_albedo_spectrum>
<rgb>
<rgb>0.588235 0.588235 0.588235</rgb>
<gamma>2.2</gamma>
</rgb>
</diffuse_albedo_spectrum>
<exponent>100</exponent>
<ior>1.3</ior>
<fresnel_scale>1.0</fresnel_scale>
<albedo_texture>
<uv_set>-none-</uv_set>
<path>stones.jpg</path>
<exponent>2.2</exponent>
</albedo_texture>
<bump_map>
<b>0.001</b>
</bump_map>
</phong>
</material>
</scenedata>
and this preview not working......and the scene is from previus v of maxingo!!!
psor
by psor » Wed Nov 28, 2007 9:30 am
"Can you guys confirm, that this only happens in scenes that are done with previous versions of Maxigo?
Sorry, can't confirm this! When I start a new scene it happens too. I'll investigate
a bit more to give you better feedback. ;o)
take care
psor
"The sleeper must awaken"
Kosmokrator
by Kosmokrator » Wed Nov 28, 2007 9:35 am
it never happend me in new scenes psor.......in some old instead i have the -none- stuf in igs.....may is a consequence.......
this strange bug needs further search!
by suvakas » Wed Nov 28, 2007 4:37 pm
Well technically the "-none-" thing is not a bug, but a feature of the previous Maxigo versions. The default uvset (when exporting a material) was set to "none" in prev. versions. In order the preview scene to work it has to be either "default" or "albedo". I changed that in latest Maxigo. That's why older scenes don't work. Cause the dfault uvset is stored into Max file and there is no way to change it (i removed the uvset selection from export parameters).
@psor
What's your CPU?
psor
by psor » Wed Nov 28, 2007 8:24 pm
@suvakas
AMD Athlon 4400+ X2 ... ;o)
take care
psor
by suvakas » Thu Nov 29, 2007 2:31 am
Gotcha.
It's more than enough
So that probably isn't an issue.
