Blendigo for v1.0
joegiampaoli
Post by joegiampaoli » Thu Nov 08, 2007 9:10 pm
If you are using this thread's Blendigo exporter, select your exit portal and in the materials drop down menu of the exporter you should find a material called (guess what?), exit portal :D
Make sure to use single faced planes for exit portals and that they are pointing or facing inward of your interior.
Joe Giampaoli
My Indigo Gallery
GNUdo
Post by GNUdo » Fri Nov 09, 2007 2:14 am
Using the last blendigo version to export scenes for indigo v1.0.2 I get this error:
Indigo Renderer v1.0.2, Windows 32-bit Release build.
SSE present.
SSE2 present.
SSE3 present.
Using 4 thread(s).
Scene file path: 'default.igs'
Using working directory path ''.
Loading Scene 'default.igs'...
IndigoDriverExcep: SceneLoaderExcep: invalid boolean value
Fatal Error: IndigoDriverExcep: SceneLoaderExcep: invalid boolean value
Modifying the line 1725 of blendigo from
	file.write("\t\t<cache_trees>%s</cache_trees>\n" %(CacheTree.val))                    #BF
to
	file.write("\t\t<cache_trees>%s</cache_trees>\n" %(IndigoBoolean(CacheTree.val)))                    #BF
solves the problem.
Pinko5
Post by Pinko5 » Fri Nov 09, 2007 2:47 am
Tnx GNUdo i have the same error and now works fine...
Luca. ;)
SmartDen
Post by SmartDen » Fri Nov 09, 2007 3:00 am
GNUdo wrote:Using the last blendigo version to export scenes for indigo v1.0.2 I get this error:
SSE present.
SSE2 present.
SSE3 present.
Using 4 thread(s).
to
solves the problem.
I know the problem and solved it already. I just forgot to upload new version :) thank you GNUdo
SmartDen
Post by SmartDen » Fri Nov 09, 2007 3:13 am
Updated
  • Fatal Error: IndigoDriverExcep: SceneLoaderExcep: invalid boolean value
    - solved
afecelis
Post by afecelis » Fri Nov 09, 2007 2:18 pm
Thanks for the fixes Smartden, and also for the "Photometric" folder! ;)
Regards,
Alvaro
SmartDen
Post by SmartDen » Fri Nov 09, 2007 7:47 pm
you're welcome :D
joegiampaoli
Post by joegiampaoli » Fri Nov 09, 2007 8:42 pm
SmartDen
Just a bit of a request, can you make it so we can select specific ies data files in the light mesh section of the exporter?
I was trying to make a quite complex scene with over 50 lights and hand editing them in XML is kinda tedious work :shock:
Thx for your work.
Joe Giampaoli
My Indigo Gallery
joegiampaoli
Post by joegiampaoli » Sun Nov 11, 2007 8:54 am
Hmmmmm, I was testing some materials and wanted to preview one and got an error, so I tested and this comes up with all test scenes, anyone with similar problems?
I'm using indigo latest (Test3) in Linux.
Joe Giampaoli
My Indigo Gallery
Post by Zom-B » Sun Nov 11, 2007 9:53 am
seems like your scenes are very old, Russian_roulette_live_prob isn't used (or only not editable?!) in Indigo since some time...
joegiampaoli
Post by joegiampaoli » Sun Nov 11, 2007 9:55 am
Well they are the material preview scenes that come with blendigo, sorry I mistyped I meant material preview scenes instead of test scenes, they are the ones bundled with blendigo.
Joe Giampaoli
My Indigo Gallery
SmartDen
Post by SmartDen » Sun Nov 11, 2007 10:07 am
wich scene have you used exactly? or occures it in all scenes?
joegiampaoli
Post by joegiampaoli » Sun Nov 11, 2007 10:11 am
With all material preview scenes, same error (Sphere, Cube, Monkey etc....).
Thx SmartDen.
Joe Giampaoli
My Indigo Gallery
SmartDen
Post by SmartDen » Sun Nov 11, 2007 10:29 am
I've updated it now. I hope it work properly now
joegiampaoli
Post by joegiampaoli » Sun Nov 11, 2007 10:37 am
Ok, I tested them all, working fine.
Thx SmartDen :D
Joe Giampaoli
My Indigo Gallery
