But there also is no "first version" of it... still beta
TopMod
SimonLarsen
Hey.
I've just downloaded TopMod, and it seems pretty easy to use, but i can't rotate my mesh. What shall i press?
I can't hear what the guy in the instructional video says, because of his crazy French accent.
Edit: Finally it worked. It was the Alt-button.
(But I though i'd already tried it.)
Great program.
Great program.
SimonLarsen
SimonLarsen
Please don't post thumbnails, I would not connect to imageshak at any price. Even if they are hosted there you can post the full image, thanks.
It's not a french accent
and one good thing to do if you use and like TopMod is to tell the author, or it's likely there will never be an update. BTW the navigation scheme is from Maya
SimonLarsen
Love the pictures posted so far.
I started tinkering with topmod/blender/indigo a few weeks ago.
Was hoping might find some others using.
I stumbled on a text file with a list of keyboard short cuts for topmod.
Some were incorrect and others were missing so i have been trying things and updating a new version of the text file over the last 2 weeks.
Ill post 2 pictures as well after this.
I name this file "TopMod Shortcut Keys 20070604.txt"
Cant attach a text file so will paste it here.
================ cut here =================
Some collected and discovered TopMod shortcut Keys.
lower case letters are just pressed.
upper case letters are shift-letter to use
? marks things i couldnt figure out or i dont understand
Modelling Commands
N = Compute Normals and Lightning
A = Deselect
c = Corner Cutting Remeshing Operation (Subdivide-Algorithm)
d,D = Doo-Sabin Remeshing Operation (Subdivide-Algorithm)
s = Catmull-Clark Remeshing Operation (Subdivide-Algorithm)
S = something ? not sure
h = Honeycomb (Dual of Root-3) (Subdivide-Algorithm)
m = Create Sierpinski Tetrahedra Remeshing Operation (Subdivide-Algorithm)
k,K = Pentagon Preserving Remeshing Operation (Subdivide-Algorithm)
z,Z = Create Wireframe
R = Rind Modeling (Scaling) with Scale Factor 0.85
Z - makes a wire frame out of the cube
H - makes a Permutahedron out of the cube
R - places a smaller cube centered within the original cube
which you can only seen by toggling ctrl s ?
o = makes a tesellated hole thru the faces toward center of object it seems - diagonal edges ?
O = makes a tesellated hole thru the faces toward center of object it seems - not diag but square edges somehow ?
Create Objects resets object state to this
C = create cube
M = create stack cube of 3x3 cubes with hole through 3 axis one cube wide
these are independent cubes not linked at all
y,Y = makes 12 Sierpinski pyramids
Non Modelling Commands
e = print edge list to console
f = prints face list to console
g,G = Grid On/Off
q,Q = Quit
x,X - removes the colored 3d axis
ctrl r = Reverse all Normals
ctrl s = toggles a heavy outline around the object
ctrl w = toggles the outline of the object
ctrl n = removes the outline of the object
ctrk z = undo
Modelling Commands
A = Deselect
C = create cube
g,G = Grid On/Off
q,Q = Quit
ctrk z = undo
This one is not made with topmod. I used Sculpture Generator.
link found here. http://www.cs.berkeley.edu/~sequin/SCULPTS/scherk.html
- Model Sculpture Generator
Scene Blender + Blendigo export
Render Indigo - im1180535551 glassmod01.jpg (141.08 KiB) Viewed 6527 times
if you slightly tweak the yellow one, you get a perfect infinite rail
the glass-thing looks good, but something is missing, there.
Maybe, you should try to only use the podest and remove the room, but therefor add a HDRi, of a park, or such... If you find one.
That sculpture generator is pretty sweeeeet. Thanks for the link.rluiten wrote:This one is not made with topmod. I used Sculpture Generator.
