CG Sphere project - 'Spherahedrons'
Lord of the Rings Junkie
Well, I'm baking at res 190 right now with a size of 1.5 m. Here's a quick render of my res 70 test. White point and tonemapping corrected with Violet.
- I know, the fluid doesn't fully intersect the sides of the bowl. I'll fix it in the final piece.;)
- out.jpg (128.86 KiB) Viewed 4226 times
Well, baking at res 190 had roughly the same effect as baking at 10m size. Do you think what I have is good enough, or should I try to get the resolution as high as I can? I don't know, it just looks too smooth to me... I'll also probably make the glass container a bit thinner.
- out.jpg (79.56 KiB) Viewed 4180 times
you HAVE to make the caustics well visible, in the final, ok?
Try hundrets of light setups xD
But I think, the caustics right now, are good already.
Dunno, how it will look, when you use that tiled texture of the cg-sphere-scene...
Uhm... can you try to add bumpmap to the tiles? will look great, too, I guess
(just use the same map, wthn different A B C, I guess)
Well, my computer pretty much died due to we think the motherboard. Fortunately I have copies of all of my .blend files on my USB flash drive. My 18th birthday is May 12, but my parents decided to make an early gift of a new motherboard, RAM, and CPU.
Old stats:
Socket 478 P4 2.4 Ghz
1 GB DDR 266 memory
250 GB P-ATA Seagate Barracuda HD
Nvidia GeForce 7300 GT AGP 8x
430 Watt PSU
New stats:
Socket LGA 775 P4 3.2 Ghz with HT
2 GB DDR2 533 memory (2 x 1 GB)
Same HD
Same graphics card
Same PSU
Can't wait 'till Newegg ships!
Old stats:
1 GB DDR 266 memory
430 Watt PSU
New stats:
Same HD
Same graphics card
Same PSU
Last edited by Lord of the Rings Junkie on Sun Apr 22, 2007 10:39 am, edited 1 time in total.
Silver linings
