Indigo Renderer 3.4.6
Re: Indigo Renderer 3.4.6
Can the ability to resume from the pigs files be added in the future, It seems to me more logical instead of igs files.
- pixie
Pigs is nothing more then a compressed igs, but beware because you can already resume them, if you put *.pigs it will then appear all pigs and procede as desired.maleemk wrote:Can the ability to resume from the pigs files be added in the future, It seems to me more logical instead of igs files.
Blender 2.6.3.17 r49666
Blendigo 3.4.7.1
It seems that I can't get a slave to use it's GPU raw power?
MASTER SYSTEM
- Dell XPS9100 - i7-980X
- GeForce GTX670 - using Cuda
NETWORK SLAVE
- ATI Radeon HD 4350
Rendering a scene with master only using Path (CPU) gives me a SPP of around 1500K SPP.
Rendering a scene with master only using Path (GPU) gives me a SPP of around 2600K SPP.
Rendering a scene with master and the slave using Path (GPU) gives me a SPP of around 4000K SPP (Slave advertise 1400SPP average). Looking at the slave console, I am getting the following message : (Warning: GPU mode requested but no appropriate device found, reverting to CPU mode.)
I went and bought another GeForce GTX670 and installed it in my slave (I could have fixed the drivers but needed raw power anyway). I ended up with :
MASTER SYSTEM
NETWORK SLAVE
Rendering a scene with the slave still gives me a SPP of around 4000K SPP (Slave advertise 1400SPP average).
Looking at the slave console, I am getting the following message : (Using CUDA device 'GeForce GTX 670') which does not make any sense since it gives me the same SSP as if it was not using it's GPU.
_____
Another thing I noticed.... When starting Indigo slave within a Windows Terminal Service session, CUDA driver cannot be found. Indigo probably looks within the terminal service session... Could it be related? I am still getting the 1400SPP when starting Indigo slave locally on the slave!!!
Please help, I really need the speed!
Blendigo 3.4.7.1
MASTER SYSTEM
NETWORK SLAVE
MASTER SYSTEM
NETWORK SLAVE
_____
Ok, I made some more tests...
I tried rendering a scene locally on the slave. Using Path CPU I am getting 780SPP. Using GPU I am getting 1520SPP. I can also confirm that my GPU goes through the roof (96% usage) while rendering and goes back down to 2% usage when I stop Indigo.
This confirms that my GPU works fine on the slave... So why I don't see the difference on the Master while using a slave?
