Indigo Renderer 3.2.0
Re: Indigo Renderer 3.2.0
Post by zeitmeister » Sat Nov 05, 2011 2:55 am
Step blend is working here for me; only getting darker areas when using any bidirectional rendermode.
Would be nice if this could be fixed, too...
Post by Zom-B » Sat Nov 05, 2011 3:05 am
StompinTom wrote:Alpha materials seem to be busted... My leaf materials don't seem to take into account any blend maps or such...
Maybe as a quick workaround for this: Try loading a texture with alpha channel into the albedo, that should work nowadays too.
Post by fused » Sat Nov 05, 2011 4:09 am
We fixed the issue on 10.7 and uploaded a new Mac build.
snorky
Post by snorky » Sat Nov 05, 2011 4:44 am
1) a gui bug: where is "render settings tab"!?!??!
2) another gui "bug": zoom level % inverted
Post by CTZn » Sat Nov 05, 2011 5:05 am
snorky wrote:1) a gui bug: where is "render settings tab"!?!??!
That's unusual, can this be fixed through the Window menu ? You could try to reform a layout...
Is this permanent or ponctual for you Snorky ?
snorky
Post by snorky » Sat Nov 05, 2011 5:39 am
Happens every time you open the program
The render settings tab is always hidden behind another tab
Moving the "up tab" it appears and then remains visible (until the next time you open the program...)
(sorry... google translation)
Post by zeitmeister » Sat Nov 05, 2011 6:30 am
@Zom-B:
transparent images?!?
PNGs with alpha? Since when does Indigo recognize them?!?
Really missed that!
sidewalk
Post by sidewalk » Sat Nov 05, 2011 6:50 am
I'm getting a permissions denial when trying to download the Mac version. All others work fine. Is it available now?
Post by CTZn » Sat Nov 05, 2011 7:27 am
@snorky: close all indigo instances but one, reset layout from the menu, rearrange layout and restart Indigo. That should do.
snorky
Post by snorky » Sat Nov 05, 2011 8:21 am
CTZn wrote:@snorky: close all indigo instances but one, reset layout from the menu, rearrange layout and restart Indigo. That should do.
no...
Rendering settings tab is hidden behind other tab (it appears only if is alone on column/row layout)
now tested on new notebook (clear installation), same problem. (and same problem with zoom %...)
Post by fused » Sat Nov 05, 2011 8:26 am
sidewalk wrote:I'm getting a permissions denial when trying to download the Mac version. All others work fine. Is it available now?
Sorry about that, should be fixed now.
Voytech
Post by Voytech » Sat Nov 05, 2011 8:58 am
Thanks so much for a speedy fix! Rendering away!
CUDA reporting out of memory now.. will investigate more.
Jeff Hammond
Post by Jeff Hammond » Sat Nov 05, 2011 10:12 am
fused wrote:We fixed the issue on 10.7 and uploaded a new Mac build.
working now.
thank you!
Zlaty Lev
Post by Zlaty Lev » Sat Nov 05, 2011 9:20 pm
I have problems with the license key of my slave.
Verification of the license key fails with 3.2.0. changed back to 3.0.14 and it works!
Win 7 64 bit
Post by Pibuz » Mon Nov 07, 2011 1:16 am
Hi guys!
Wonderful mood change between the old sky and the new one! VEEEERY GOOD!
..but I must report that the new sky is limited to a half-sphere. The old sky model (in skindigo it's called "legacy sky") worked well, and still does if enabled.
See attachments. Thanks!!!
Users browsing this forum: No registered users and 194 guests
