Blendigo (for Blender 2.5x) 3.2.0.0
dougal2
Re: Blendigo (for Blender 2.5x) 3.2.0.0
Post by dougal2 » Sat Nov 12, 2011 2:39 am
dag wrote:No light sources available when only using envmap.
I can't reproduce this here, it seems to work correctly. Can you provide a .blend file of your setup for me to test?
dag
Post by dag » Sat Nov 12, 2011 4:43 am
Looks like only files in C:\Users\... doesn't work. Try putting it in there.
Windows UAC enabled if that matters.
dougal2
Post by dougal2 » Sat Nov 12, 2011 4:52 am
dag wrote:Looks like only files in C:\Users\... doesn't work. Try putting it in there.
Still works for me with a .exr in "My Documents" and UAC on (win 7 x64)
dag
Post by dag » Sun Nov 13, 2011 1:50 am
This one works but only when files are in 2 folders below the documents folder.
In any other user folders no light sources.
env.zip
(71.86 KiB) Downloaded 364 times
dougal2
Post by dougal2 » Sun Nov 13, 2011 3:16 am
dag wrote:This one works but only when files are in 2 folders below the documents folder.
OK, I've seen the problem now, but not sure what's causing it yet. I think it might have something to do with the output path being "/tmp\" with the .blend file on the C:
I didn't spot this before, since my testing .blend files are normally on my D: data disk.
(I also normally set my output path to either "//" or "d:\Temp").
I'll see what I can do to prevent problems with .blend on C: and "/tmp\"
dougal2
Post by dougal2 » Sun Nov 13, 2011 3:35 am
This issue was to do with incorrectly set working directories during export and therefore incorrectly resolved relative paths - it'll be fixed in the next release :)
Post by StompinTom » Sun Nov 13, 2011 6:00 am
Eagerly waiting for next release! Do you think the 'proxy'/igmesh linking will be faster too?
dougal2
Post by dougal2 » Sun Nov 13, 2011 7:53 am
Yes, I've removed the igmesh loading and will assume the proxy object has the same number of materials assigned as the igmesh. I've also added support for obj format meshes.
Post by StompinTom » Sun Nov 13, 2011 8:09 am
Amazing! Can't wait to throw geometry at Indigo quicker than ever.
FakeShamus
Post by FakeShamus » Sun Nov 13, 2011 10:20 am
awesome! this will kind of change my life - thanks!
solarray
Post by solarray » Mon Nov 14, 2011 12:40 am
No one has problems with uv mapping ? Mine are totally distorted with this exporter and blender 2.60a/2.58a. The old exporter 3.0.10 works fine.
Post by StompinTom » Mon Nov 14, 2011 1:57 am
solarray wrote:No one has problems with uv mapping ? Mine are totally distorted with this exporter and blender 2.60a/2.58a. The old exporter 3.0.10 works fine.
Now that you mention it, so am I... UVs are very messed up :S
FakeShamus
Post by FakeShamus » Mon Nov 14, 2011 2:07 am
Yes, I have very distorted textures for all UV mapping too.
dougal2
Post by dougal2 » Tue Nov 15, 2011 1:46 am
I do confirm that non-trivial UV mapping is screwed. I'll try and fix it today :)
dougal2
Post by dougal2 » Tue Nov 15, 2011 2:47 am
I have a fix
