Guide For Exporter Writers
Hey Indigo people!
What's a good default pre-scale value? SkIndigo has been using 6.0 for a long time and I am starting to notice that most the of renders uploaded by new SkIndigo users look like the pre-scale is set too high.
I think the reason I set it so high is because my old computer had a really dark monitor and I had to use a higher pre-scale value for the render to look right. Now, when I see renders on my new laptop and my computer at work, they look too bright.
Maybe a value of 4.0 (like Blendigo) is the way to go. It should be a value that will give a good render for a variety of lighting situations.
Does anyone find Blendigo's default value of 4.0 too low? Too high?
Thanx.
Thanx.
Hi all, I have a question about how can I calc the aperture radius
I have a camera with 24mm focal lenght, zoom factor 3.2, focal dis 1 and camera f-stop 4.
I don't understand very good this. How can I calc the aperture radius with my values ?
We have
N = f / d
where
N = f-number, f = focal length, d = aperture diameter.
Therefore
r = f / (N*2)
where
r = aperture radius.
Here is how I do it for Maxigo:
f-stop = 4
sensor_width = 0.035
sensor_distance = sensor_width / (2*tan(cameraFOV/2))
aperture_radius = sensor_distance / ( f-stop * 2)
While trying to write Rotation Matrixes for the MayaToIndigo exporter,
well, we got stuck. I checked the Skindigo tool but couldn't find any reference to rotation code.
As this will eventually concern every exporter that generates instances or that will implement efficient transformation-based animations, can somebody shed some light on this?
Here is the baby-code for generating rotation matrixes, or at least some starting point. I imagine it will be something similar for other programming / script languages.
$x = `getAttr locator1.rx`;
$y = `getAttr locator1.ry`;
$z = `getAttr locator1.rz`;
float $xCos = cos (deg_to_rad($x));
float $xCo_ = -1 * `cos (deg_to_rad($x))`;
float $xSin = `sin (deg_to_rad($x))`;
float $xSi_ = -1 * `sin (deg_to_rad($x))`;
float $yCos = `cos (deg_to_rad($y))`;
float $yCo_ = -1 * `cos (deg_to_rad($y))`;
float $ySin = `sin (deg_to_rad($y))`;
float $ySi_ = -1 * `sin (deg_to_rad($y))`;
float $zCos = `cos (deg_to_rad($y))`;
float $zCo_ = -1 * `cos (deg_to_rad($y))`;
float $zSin = `sin (deg_to_rad($y))`;
float $zSi_ = -1 * `sin (deg_to_rad($y))`;
matrix $mx[3][3] = << 1 , 0 , 0 ;
0 , $xCos, $xSi_;
0 , $xSin, $xCos>>;
matrix $my[3][3] = << $yCos , 0 , $ySin ;
0 , 1, 0 ;
$yCo_ , 0, $yCos>>;
matrix $mz[3][3] = << $zCos , $zSi_ , 0 ;
$zSin , $zCos, 0;
0 , 0, 1>>;
matrix $mAll[3][3] = $mx * $my * $mz;
print "\nrotation Matrix:";
print $mAll; And as a reference, the latest version wich works only for rotations around up axis.
This approach is as follows (Z up):
1° Rotation around Z
2° Rotation aroun X
3° Second rotation around Z
Here I can't define the value for the second rotation around Z, I'm using Y rot value but seems wrong.
Indeed we need help. Thanks.
float $xCos = cos (deg_to_rad($rix));
float $xCo_ = -1 * `cos (deg_to_rad($rix))`;
float $xSin = `sin (deg_to_rad($rix))`;
float $xSi_ = -1 * `sin (deg_to_rad($rix))`;
float $yCos = `cos (deg_to_rad($riy))`;
float $yCo_ = -1 * `cos (deg_to_rad($riy))`;
float $ySin = `sin (deg_to_rad($riy))`;
float $ySi_ = -1 * `sin (deg_to_rad($riy))`;
float $zCos = `cos (deg_to_rad($riz))`;
float $zCo_ = -1 * `cos (deg_to_rad($riz))`;
float $zSin = `sin (deg_to_rad($riz))`;
float $zSi_ = -1 * `sin (deg_to_rad($riz))`;
matrix $R0[3][3] = << $zCos , $zSi_ , 0 ;
$zSin , $zCos, 0;
0 , 0, 1>>;
matrix $Rx[3][3] = << 1 , 0 , 0 ;
0 , $xCos, $xSi_;
0 , $xSin, $xCos>>;
matrix $R1[3][3] = << $yCos , $ySi_ , 0 ;
$ySin , $yCos, 0;
0 , 0, 1>>;
matrix $Rresult[3][3] = $R1 * $Rx;
matrix $Rresult[3][3] = $Rresult * $R0;
print $Rresult;
matrix $RtoY [3][3] = <<1, 0, 0;
0, 0, -1;
0, 1, 0>>;
if ($upAxis == "y")
$Rresult = $Rresult * $RtoY;
}1° Rotation around Z
2° Rotation aroun X
Yeah, it's EZ with SketchUp API.suvakas wrote:Why are you doing this manually?
Can't you get a nice rotation/transform matrix out of Maya?
trans=entity.transformationI can't answer your question suvakas, as the code I expose here is from someone's else algorithm and it appeared that afternoon that he hadn't the problem clear in mind so the algorithm is finally not suitable.
I do ignore almost everything about rotation matrices...
Anyhow the "how" is not the point here, we need to know the right composition of the RM and their multiplication order, if I understood enough. Thought you guys had cracked that easily...
That said, suvakas, that was a good question. Inquiring now...
>> Indeed every object has:
- matrix
- world matrix
- parent matrix
and each of these has an inverse matrix also available as output. bkircher, maybe we have been fooled...
- matrix
- world matrix
- parent matrix
Sadly, we can't.
But the Maya Help is great in that respect:
a little further down the line, it is said:
, and well, that's it, basically.
Maya is thinking Y-up to my experience: In a Z-up environment, probably a XYZ rotation order with Y up is part of the problem?
(We can get the world 4x4 matrix, does this help ?)
Any help is appreciated on this issue...
matrix = SP * S * SH * SP * ST * RP * RA * R * RP * RT * TCode: Select all
RX = | 1 0 0 0 | RY = | cy 0 -sy 0 |
| 0 cx sx 0 | | 0 1 0 0 |
| 0 -sx cx 0 | | sy 0 cy 0 |
| 0 0 0 1 | | 0 0 0 1 |
RZ = | cz sz 0 0 | sx = sin(rx), cx = cos(rx)
| -sz cz 0 0 | sy = sin(ry), cx = cos(ry)
| 0 0 1 0 | sz = sin(rz), cz = cos(rz)
| 0 0 0 1 |Maya is thinking Y-up to my experience: In a Z-up environment, probably a XYZ rotation order with Y up is part of the problem?
