Cool! How are you exporting scenes to Mitsuba? Only found the older exporter and haven't tested it yet... Does it work?CoolColJ wrote:Veach MLT - 10min render - only source of light is indirect lighting through windows and geometry seams![]()
No exit portals or anything hereWanted to see how many samples to reach a clean shadows with Veach MLT
8192 samples here - 30 min render
Mitsuba renderer
Re: Mitsuba renderer
I'm just importing OBJ scenes, it will also load DAE and another formatStompinTom wrote:Cool! How are you exporting scenes to Mitsuba? Only found the older exporter and haven't tested it yet... Does it work?CoolColJ wrote:Veach MLT - 10min render - only source of light is indirect lighting through windows and geometry seams![]()
And I guess you can edit the saved XML scene files, after importing, like old schoool Indigo
Ok I export a OBJ-File.
But does a OBJ-File also contain the lightsources from my Blenderfile ?
And how do I have to setup Materials, Sunlight,... ?
Do I have to edit an *.xml file ?
BTW: It also supports instancing geometry, see here: http://www.mitsuba-renderer.org/devblog/
Did anyone did some heavy test with complex Interiorscenes yet ?
Kind regards
Alain
Kind regards
Alain
Win 7 64 Bit, 8 GB RAM, Geforce GTX 480, Blender 2.62, Indigo RT Trial, Blendigo 3.2.12.0
You might be better off exporting Collada 1.4 .DAE file formatAlain wrote:Ok I export a OBJ-File.
Kind regards
Alain
But there is a Blender exporter of sorts done by someone. Mitsuba will convert it to the new scene format if it's old in any case.
http://bartoszstyperek.wordpress.com/20 ... -exporter/
I don't know Blender well enough to get it to work, where to put it, which of the million versions of Blender to use etc etc
Mitsuba was updated again, better .OBJ and .DAE import.
I finally got this scene into it, but there are some shading errors I need to sort out
I hand edited the water in.
12 min or so render! Very quick on the caustics - by far the fastest unbiased renderer in this aspect
Manifold Perturbation is like magic for this, Indigo needs this!
I've done this scene in Indigo and Luxrender and it's pretty slow. 2 objects sitting in water
15-20mins in Mitsuba
Blender Mitsuba exporter has been updated!
http://bartoszstyperek.wordpress.com/20 ... orter-1-0/
I WANT A SKETCHUP EXPORTER!!!!!!!!
