waz
Post by waz » Tue Jan 11, 2011 7:39 am
troopers wrote:
waz wrote:Simply interior :D
waz
Waz please tell me what texture You use on 2nd picture? can you share this texture?
Hi troopers,
the texture of the sofa was downloaded from cgtexture.com (fabric->plain fabric) :)
waz
troopers
Post by troopers » Tue Jan 11, 2011 8:08 am
thx man! <beeR>
dcm
Post by dcm » Tue Jan 11, 2011 11:45 am
working on this...
Soup
Post by Soup » Tue Jan 11, 2011 4:01 pm
Oh Dcm... *swoon*
Thom
Post by Thom » Wed Jan 12, 2011 3:55 pm
ENSLAVER wrote:Finally got all my 3D stuff installed again. Just some fun to get used to all those hotkeys and shizzle.
Awesome. May I ask how you did it?
ENSLAVER
Post by ENSLAVER » Wed Jan 12, 2011 6:35 pm
Mostly 3dsmax stuff, the displaced island (displace modifier), the trees are indigo proxies via the max plugin, water is just a modified bluey glass with IOR set to 1.33 with bump map for waves. Used the max 2011 sculpt tools (yeah they kinda suck but are ok for quick geometry) for the underwater sand bars/etc
a couple of the same scene, water bump was low res =\
Post by Zom-B » Thu Jan 13, 2011 12:27 am
looks promissing, but why not using ISL based noise for water bump?
or even better displacement (if there is enough RAM available)
carsten_fokuspunkt
Post by carsten_fokuspunkt » Sat Jan 15, 2011 2:35 am
started up indigo after a long break....just a small time-wasting project :)
Post by Headroom » Sat Jan 15, 2011 5:31 am
carsten_fokuspunkt wrote:....just a small time-wasting project :)
Very nice Render! Looks like time well spend rather than wasted :wink:
dcm
Post by dcm » Mon Jan 17, 2011 1:03 am
just tap (testscene from which im working on atm)
dcm
Post by dcm » Mon Jan 17, 2011 11:05 am
testing some bathroom stuff....noisy because it was rendered for 1 hr only
Post by CTZn » Mon Jan 17, 2011 7:31 pm
dcm, first warning with going off topic :lol:
Excellent sampling consistency throughout the image, lighting is not the least for you. Good job !
bidir/mlt/glassAcc ?
dcm
Post by dcm » Mon Jan 17, 2011 8:28 pm
Here is the pic after few hours later. :)
There is one plane in window (2000W, 6504) and 2 planes behind camera (one 4300k and one 8500k). Lamps are 60W 3600k. I used MLT bidir with SS4. There is still decent noise due to high glossy tiles and floor. Of course, room is lil longer behind the camera due to space needed for camera placing.
Carpet/Towels are displaced by 3 subdiv (meshes are higly subdivided directly in Max)
Post by zeitmeister » Mon Jan 17, 2011 9:36 pm
Looks great!
But indeed very noisy... can you specify which light emitter causes the most noise?
Perhaps the one behind the camera?
If you increase the power dramatically for this/these, and crank it down manually in the Indigi GUI, you might get rid of the noise.
But I guess that you know this workaround for a lonf time already. :)
dcm
Post by dcm » Mon Jan 17, 2011 10:40 pm
Yes i know this, thanks! :)
