Indigo 0.7F exporter here! Features added/Comments welcome!
Hi, Wedge
thanks, but i am sorry, i got this:
Compiled with Python version 2.3.
Checking for installed Python... got it!
INDIGO EXPORT - Saving to '/something.xml'...
File "Indigo-07t5b3-Exporte", line 750, in gui
File "Indigo-07t5b3-Exporte", line 624, in save_still
File "Indigo-07t5b3-Exporte", line 541, in save_indigo
AttributeError: 'Blender SceneObSeq' object has no attribute 'camera'
i am starting to think about Blender bug, or something between Heven and Earth which i cannot understand
Hello! I posted another maintenance release. Also moved primitive object checking to the front so that they should export nearly instant. Merged / cleaned up most of the code from the large mesh support feature.
Carbon: This time the exporter grabs the camera much like the code you listed above. Hopefully this one will work for you.
processing Camera
File "Indigo-07t5b3-Exporte", line 741, in gui
File "Indigo-07t5b3-Exporte", line 616, in save_still
File "Indigo-07t5b3-Exporte", line 544, in save_indigo
AttributeError: lens
i feel ashamed for posting only errors...
processing Camera
Thanks Tobak.
Maintenance release number 3 posted. I am thinking of slowing down my work on this exporter so I can get ready to enjoy the spring season.
Carbon: I played with different ways to get the camera data out of the exporter and at one point I actually received the error you listed above. I do not know why or how it happened though. But, I think this new version will fix it.
Here is the new version of exporter for Indigo 7t7. (posted at the front) If you find a bug and want it fixed, please report it here.
If possible, try and make sure the bug is an exporter bug and not a bug in your scene or a bug in Indigo 07t7. Thanks!
Hi Scorpius,
Not sure why you get these errors. Tried testing with multiple cameras so that the name changed to . 001 and . 002 but it still works fine for me.
I enjoy seeing bugs get reported! It means I can try and make this work correctly for everyone that uses it. I mean I am not happy to see bugs (I try to write error free code), but they pop up now and then, especially since Blender/Python comes in many different versions and on different platforms. (I can only test on my computer that is Windows platform, also sometimes use newer builds of Blender)
Anyway, after some thinking and testing I am hoping you can try this code here:
Remove or comment out the old line with a # character:
#camData = Camera.Get('Camera')
Add this line right under it:
camData = Camera.Get(camObj.getData(1))
See if that works for you and if it does, I should be able to update the main version. Using object code to get camera data values seems to cause trouble for other users so I am hoping the above code fixes the issue.
Thanks again for reporting this problem and I hope this fix works for you!
Users browsing this forum: No registered users and 66 guests
