Indigo Exporter for 0.7t5 - beta release
First of all: THANK YOU EVERYBODY SOOOO MUCH for the great job! I stopped testing Indigo when the BL-Exporter didn't work anymore, now fused makes me happy again!
Unfortunately the exporter makes my C4d crash (both versions 9.6 and 10)..
if I open the test scene delivered with the exporter, or the 'exporter test.rar' of WLAD, they are exported correctly, and indigo runs ok. But if I click on the 'indigo render settings' tab, I get those error messages:
Symbol Type_latlong not found.. line 80
Symbol Type_spherical not found line 80
Error reading resource: file .......res-description-tmyrendersettingsexp.res line 88
I tried to add the two code-lines at the end of the tmyrendersettingsexp.str, asProtocultura suggested:
TYPE_LATLONG "Lat/Long";
TYPE_SPHERICAL "Spherical";
but I get the same message..
What am I doing wrong?
thank you and greets from Italy
i noticed a difference between
\res\strings_de\description\tmyrendersettingsexp.str
and
\res\strings_us\description\tmyrendersettingsexp.str
of a few lines at the end. i fixed that, now Cinema doesn't crash immediately when i ckick on the render setting icon (that works well now), but crashes when i try to save the exported file. I get this message:
does anybody have the same problem?
thanks, bye!
and
thanks, bye!
- error.jpg (31.38 KiB) Viewed 5386 times
finally, new release!
sry for the long delay.
INDIGO EXPORTER FOR C4D 0.2.5b
download exporter here (or below)
the file contains "sampleScene.c4d" for everyone who still doesnt know how to setup stuff.
fixed-list 0.2.5b:
* env-maps
* finally rotation (barely tested)
* should not crash on export (if it does pls send me your scene)
new in 0.2.5b:
* the often requested defaultMat (diffuse, r,g,b = 0.85)
* several things that i dont know anymore
* triangulation for .obj export
known bugs/issues 0.2.5b:
* sometimes you have to guess the right fields, didnt find out how to hide them yet
* normal problem. normal_smoothing = false by default
* some little memory leaks, should not cause problems, will be fixed soon
please post bugs
fixed-list 0.2.5b:
* env-maps
new in 0.2.5b:
please post bugs
- Indigo Exporter 0.2.5b.zip
- Indigo Exporter for 4D 0.2.5b
- (354.42 KiB) Downloaded 715 times
Thank you fused for the new release!
And also thanks for implementing the default mat.
But when I export from C4D, the scene is still always named "justsomerandomcrap.xml" whether if I add the extension ".xml" to my chosen name or not. But the .3ds and .obj files get the right names.
The menue point "Info..." also seems to do nothing yet.
(I tried both of these with the C4D releases R9.6 and R10.1)
