Indigo Renderer 2.4.2 Released
Re: Indigo Renderer 2.4.2 Released
Post by fused » Wed Apr 14, 2010 1:31 am
forgeflow wrote:Will there be a Mac build to play with?
Not right now. It is scheduled for next wednesday, iirc.
SaphireS
Post by SaphireS » Wed Apr 14, 2010 1:33 am
64bit works fine after some early first tests, however, could you pleas add the dark theme as an option in the "options-menu" ? ;)
Post by fused » Wed Apr 14, 2010 1:36 am
SaphireS wrote:64bit works fine after some early first tests, however, could you pleas add the dark theme as an option in the "options-menu" ? ;)
It was a bit unfinished so we had to remove it :)
I'll maybe finish and upload it tomorrow if I can find some time for it. But I'm packed with lots of work currently.
SaphireS
Post by SaphireS » Wed Apr 14, 2010 1:39 am
Don't abandon any important work because of this, but if you have the time I would appreciate it. :)
dcm
Post by dcm » Wed Apr 14, 2010 2:08 am
I tried to render same scene in 2.4.2 and it seem that it tooks correct bump values and other settings.
In 2.2.12 i wasnt able to see stucco bump, floor bump correctly but on MDB model these settings was visible. 2.4.2 rendered correct (and different) image i think.
Im not sure why, but i had always bad feeling that mdb model isnt in the correct scale.
Im just testing other scenes.
Post by suvakas » Wed Apr 14, 2010 5:51 am
pixie wrote:I get this error:
Error: Could not make a TCP connection to server 127.0.0.1:7200, Error code: WSAECONNREFUSED
Tried registering the Indigo Network Manager and I got this:
Error validating licence: Could not find '</licence_data>'
Same thing happens here too.
Post by suvakas » Wed Apr 14, 2010 6:19 am
indigo_console is not working.
Here's the error message:
indigo_console.exe has failed to start because nvcuda.dll was not found.
Because of this material previews are not working inside Maxigo.
eman7613
Post by eman7613 » Wed Apr 14, 2010 6:23 am
suvakas wrote:indigo_console is not working.
Does that dll mean no OpenCL implementation :( ?
Post by pixie » Wed Apr 14, 2010 6:57 am
Perhaps this helps...
Post by suvakas » Wed Apr 14, 2010 7:27 am
I'm using ATI card. I can't use Nvidia drivers.
Post by Zom-B » Wed Apr 14, 2010 7:38 am
I'm on ATI too... I hope for some openCL support... waiting until then to get a new 5xxx card :)
anyway, the nvcuda.dll has be be placed into the Indigo Folder to get found ;-)
Post by pixie » Wed Apr 14, 2010 9:46 am
Zom-B wrote:I'm on ATI too... I hope for some openCL support... waiting until then to get a new 5xxx card :)
Not always, if the path is set it could be reached from outside unless it's hardcoded somehow...
Updated: It works like a charm and I didn't have to change my system. I have a GTX 285, and I have to say that I'm impressed, seeing is believing.
Post by Zom-B » Wed Apr 14, 2010 11:47 am
pixie wrote:Updated: It works like a charm and I didn't have to change my system. I have a GTX 285, and I have to say that I'm impressed, seeing is believing.
how about some numbers/images...
Post by lycium » Wed Apr 14, 2010 12:06 pm
Region selection: this change was reverted by accident, sorry! It is indeed intended for use with region rendering.
GPU support: We're developing both CUDA and OpenCL support, though it's currently unused.
Post by neo0. » Wed Apr 14, 2010 1:46 pm
Nice! Any date for the dark theme?
Users browsing this forum: No registered users and 61 guests
