3D wood shader
Re: 3D wood shader
Post by fused » Wed Feb 24, 2010 12:13 am
more wood. still the same shader.
fenerolina
Re: 3D wood shader
Post by fenerolina » Wed Feb 24, 2010 1:27 am
Wow Fused! This oak looks pretty good!
What distracts my eyes now is the simetrical/straightness draw of the wood vains. Would it be possible to add some little knots on the wood? I may ask too much but i really don't know if there're any limits in isl :) . Here is the female joint showing a nice wood vain draw.
Thank you!
Re: 3D wood shader
Post by zeitmeister » Wed Feb 24, 2010 2:17 am
Very promising, fused!
Can you peek anything from the C4D-wood shader? Because it's quite nice...
Phoenix
Re: 3D wood shader
Post by Phoenix » Wed Feb 24, 2010 2:43 am
@Fused:
Hey, that looks quite good!
Perhaps you can even adapt it straight from C4Ds Banzi-Shader for your Cindigo exporter. ;o)
@fenerolina:
At least the one of the effects (curled spot) that you emphasized in your image, you would get easily if you simply put the shader in a small angle "into" the object. You now what I mean?
But yeah, knotholes would be nice too.
Re: 3D wood shader
Post by CTZn » Wed Feb 24, 2010 2:53 am
Some low frequency and low density Billow noise into the vein noise should create those locks...
galinette
Re: 3D wood shader
Post by galinette » Wed Feb 24, 2010 5:47 am
What is billow noise?
Etienne
Eclat-Digital Research
http://www.eclat-digital.com
Re: 3D wood shader
Post by CTZn » Thu Feb 25, 2010 1:27 am
Of one single octave with randomized width, yes. Maya calls it billow at least :)
Ah, what is Billow noise, sry misread you.
Anders Egleus figured the math behind maya's 3D Texture called Volume Noise.
The math that Anders figured out is this
origin = -1 * position * frequency / (scale * 16)
This billow noise is a variation. I don't know how relevant the formula is, and probably many other noise types can do the woodlocks job.
Users browsing this forum: No registered users and 64 guests
