Strange diagonal lines on the render - is it just me?
plaurits
Re: It's not because of WINE!
Post by plaurits » Tue Dec 05, 2006 6:49 am
skypa wrote:a) resizing everything in your scene thus making it smaller and b) using a larger resolution for the render.
Thanks for the tip! this actually works. However it might not be the final solution to the problem, because there is clearly a bug somewhere in the line. But is it caused by blender, indigo, wine or maybe a combination? what a shame i'm not a coder :D
Also thanks for your renderings, it seems this bug also influence the brightness of the final image. If i keep on rendering a scene with the lines, in time they will become less and less visible, but the image will be overall much darker than it really should be.
LaurentA wrote:Go back to Blender, and change the renderer back from Yafray to Blender internal, and export again.
Hmmm, it was set to the internal render from the start, and switching between the two and then exporting the scene doesn't really make any difference. But maybe you are experiencing a related bug somehow. Anyway, there certainly is a bug (or two?) somewhere, that's for sure.
peer
Post by peer » Sat Dec 09, 2006 3:18 am
I'm rendering your scene under OS X (crossover) and it looks OK here. Crossover uses wine I think.
Regards,
Peter
