Problem with Microsoft Active X on Indigo site front page
This forum is for discussing the Indigo Website, The community, its organization and the online tools/resources.
ROUBAL
Re: Problem with Microsoft Active X on Indigo site front page
Post by ROUBAL » Fri Jan 29, 2010 7:09 am
Hi! It works now. Thank you !
So, I'll stay with IE7 until bigger troubles !o)
Post by suvakas » Fri Jan 29, 2010 9:14 am
Now sub-menus are not working properly anymore on IE8.
They are geting cut off from the bottom and forum links appear on top of the menus. I think it's related to that slide show thingy.
Soup
Post by Soup » Fri Jan 29, 2010 10:39 am
That's been fixed (hopefully, I just checked in IE8), IE should refresh itself soon for you.
Godzilla
Post by Godzilla » Sun Feb 07, 2010 4:38 am
Godzilla wrote: you may want to get some images in there that aren't all archviz.. and perhaps images which aren't noisy.
Any plans for doing this?...
Post by suvakas » Fri Feb 12, 2010 4:58 am
Soup wrote:That's been fixed (hopefully, I just checked in IE8), IE should refresh itself soon for you.
Well..menu is still not working with my IE8. I can only select the 1st sub-item from any category and half of the menu gets cut off from the bottom.
Doug Armand
Post by Doug Armand » Fri Feb 12, 2010 9:21 am
Sorry I can't help but it works ok here on IE8 Win7x64
Doug
Doug Armand
Soup
Post by Soup » Fri Feb 12, 2010 9:25 am
Yeah that's weird, I can't reproduce it either. Is it only on the front page that is doing it? It's probably the flash sitting over top of the menus, try on other pages.
Post by suvakas » Fri Feb 12, 2010 6:32 pm
Thanks for the answer guys.
I sloved it. I had "Compatibility view" on for Indigo page.
Post by CTZn » Mon Feb 22, 2010 3:14 pm
Where's this setting please suvakas ? I have the same issue as you described, I must try it.
Post by suvakas » Mon Feb 22, 2010 8:26 pm
In IE8 it is under drop down list Page > Compatibility View
Post by CTZn » Tue Mar 02, 2010 12:19 am
There's no such option in IE7, too bad. I'll fix that by acquiring a 64 bits system asap.
