ISL shader nodes
Re: ISL shader nodes
Sweet, now it just needs some vegetation and snow shaders
hehe, theres a blend shader for that!
circular gradient + fbm again
the snow is actually a little more displaced than the rocks
oh and of course the shader generated by cindigo:
<material>
<name>rock_mid0_b_l_e_n_d_A</name>
<oren_nayar>
<sigma>
<constant>0.200000</constant>
</sigma>
<albedo>
<texture>
</texture>
</albedo>
<texture>
<uv_set>default</uv_set>
<path>..\..\..\..\..\Desktop\rock_03.jpg</path>
<exponent>2.200000</exponent>
<a>0.000000</a>
<b>1.000000</b>
<c>0.000000</c>
</texture>
<displacement>
<shader>
<shader>
<![CDATA[def Vec3ToReal(vec3 v) real : ((doti(v) + dotj(v) + dotk(v)) / 3.0)
def noise01(vec3 v) real : ((noise(v) + 1.0) * 0.5)
def noise01(vec2 v) real : ((noise(v) + 1.0) * 0.5)
def noise01(real r) real : ((noise(r) + 1.0) * 0.5)
def fbm01(vec3 v, int oc) real : ((fbm(v,oc) + 1.0) * 0.5)
def fbm01(vec2 v, int oc) real : ((fbm(v,oc) + 1.0) * 0.5)
def fbm01(real r, int oc) real : ((fbm(r,oc) + 1.0) * 0.5)
def mulCompVec2(vec2 a, vec2 b) vec2 : vec2(doti(a) * doti(b), dotj(a) * dotj(b))
def mulCompVec3(vec3 a, vec3 b) vec3 : vec3(doti(a) * doti(b), dotj(a) * dotj(b), dotk(a) * dotk(b))
def eval() real: ((Vec3ToReal(lerp(vec3(1.00000, 1.00000, 1.00000), vec3(0.00000, 0.00000, 0.00000), length(vec2(0.5,0.5) - getTexCoords(0)) * 2.0 )) * 1.00000 + 0.35000 * fbm01(mulCompVec2(getTexCoords(0) * 10.0, vec2(1.00000, 1.00000)),8)) * 1.50000 + 1.00000 * noise(mulCompVec2(getTexCoords(0) * 10.0, vec2(0.25000, 0.25000)))) * 6.00000]]>
</shader>
</shader>
</displacement>
</oren_nayar>
</material>
<material>
<name>snow_mid1</name>
<phong>
<ior>1.500000</ior>
<diffuse_albedo>
<constant>
<rgb>
<rgb>0.900000 0.900000 0.900000</rgb>
<gamma>2.200000</gamma>
</rgb>
</constant>
</diffuse_albedo>
<exponent>
<constant>250.000000</constant>
</exponent>
<displacement>
<shader>
<shader>
def eval() real: ((Vec3ToReal(lerp(vec3(1.00000, 1.00000, 1.00000), vec3(0.00000, 0.00000, 0.00000), length(vec2(0.5,0.5) - getTexCoords(0)) * 2.0 )) * 1.00000 + 0.35000 * fbm01(mulCompVec2(getTexCoords(0) * 10.0, vec2(1.00000, 1.00000)),8)) * 1.50000 + 1.00000 * noise(mulCompVec2(getTexCoords(0) * 10.0, vec2(0.25000, 0.25000)))) * 6.10000]]>
</shader>
</shader>
</displacement>
</phong>
</material>
<material>
<name>rock_mid0</name>
<blend>
<a_name>rock_mid0_b_l_e_n_d_A</a_name>
<b_name>snow_mid1</b_name>
<step_blend>false</step_blend>
<blend>
<shader>
<shader>
def eval() real: (Vec3ToReal(lerp(vec3(1.00000, 1.00000, 1.00000), vec3(0.00000, 0.00000, 0.00000), length(vec2(0.5,0.5) - getTexCoords(0)) * 2.0 )) * 1.00000 + 1.00000 * fbm(mulCompVec2(getTexCoords(0) * 10.0, vec2(0.60000, 0.60000)),8)) * 2.00000]]>
</shader>
</shader>
</blend>
</blend>
</material>
I just got the perlin and fbm shader code indigo uses from nik, so expect the shader previews and c4d internal renderings to be quite accurate
trying to add some turbulence to gradient shaders (because c4ds gradient shaders can do that).
doesnt quite look as in c4d but its a start
left 50% turbulence, right 25%
oh, and the shader:
oh, and the shader:
<material>
<name>diff_tran</name>
<diffuse>
<albedo>
<shader>
<shader>
<![CDATA[
def fbm01(vec2 v, int oc) real: (fbm(v,oc) + 1.0) * 0.5
def noise01(vec2 v) real: (noise(v) + 1.0) * 0.5
def eval(vec3 pos) vec3: lerp(vec3(0.75,0.0,0.0),vec3(0.0,0.75,0.0),doti(getTexCoords(0)) + (fbm(getTexCoords(0) * 5.0,8) * 0.5))
</shader>
</shader>
</albedo>
</diffuse>
</material>
shader previews are fairly accurate, c4d internal and indigo renderer:
Great stuff fused ! One more year and I'll be there I hope
*cough* that was some dust by the way, I was just lurking for sumthin around and found this !
hello
i start to dive into tech.reference of isl.
But i look in section "Built-in functions – miscellaneous functions", at function posOS()
I have question if dynamic object hit surf, then initiate noise reproduction(like frost or cracks).
Is it possible in isl? Vector of intersection will be return by xpresso or python.
I will to try, it's only concept.
I'm sorry for my bad English
Hello and me again.
Yves you posted new cindigo version with isl-fixes and new sdk.
Can we wrap it(ISL) into such shader structure http://code.vonc.fr/?a=13 or http://code.vonc.fr/c4d/python/examples ... y-Fresnel/ ?
Warp isl symbols in brackets(with inherited options) and unwrap when render-data init().
this experiment don't me let up
(sorry for my English)
