Ocean Horizon
Re: Ocean Horizon
Post by CTZn » Thu Aug 20, 2009 6:31 pm
This serie is more pictural, I like it still.
You have to modify the ratio between the focal distance and the aperture radius to modify the size of diffraction.
:mrgreen: F-stop ;)
Maybe the scattering was making a difference, water is not that similar between each version...
Re: Ocean Horizon
Post by Whaat » Fri Aug 21, 2009 7:21 am
Pibuz wrote:..btw, my water shows less turbulence than the one by Whaat.. Only God knows why..
As it turns out, I modified the shader code before I sent the scene to you. oops!
Polinalkrimizei
Re: Ocean Horizon
Post by Polinalkrimizei » Tue Oct 04, 2011 6:41 pm
Re: Ocean Horizon
Post by StompinTom » Wed Oct 05, 2011 3:36 am
Pibuz wrote:Ok, here are two renders showing some scene improvements, and a first test with non circular diffraction. I know this isn't a clear render: that's my idea. A foggy industrial environment, in some sad autumn morning. That's why it's all grey and dirty.
The diffraction effect turns out to be pretty big (..what's the parameter to reduce the size? to be continued..), if you have an inspective eye you can spot two big artifact caused by don't know what.
Other tests will follow.
These (and previous ones) are awesome!
You can reduce the effect of the diffraction by using a larger aperature (f11, f8, etc.).
Re: Ocean Horizon
Post by Pibuz » Thu Oct 06, 2011 6:51 am
You guys know that these posts of mine are something about 2 years old.. :lol:
Would have helped a lot to know good things about diffraction back then! :D
But don't worry: I've still got a lot to learn from diffraction and its several tricks: hope I can bother you guys with some more tests and questions soon!
lape
Re: Ocean Horizon
Post by lape » Sat Mar 01, 2014 3:49 am
Just found this old post and wonder what kind of map was used to create these beautiful waves...
Perhaps someone can push me in the right direction, or give me a hint where I find a nice bumpmap to achieve some rippled waves for a quayside... Or share one :wink:
Lars
24 hours isn't enough
http://www.werkraum3d.com
Re: Ocean Horizon
Post by Pibuz » Sat Mar 01, 2014 4:05 am
In my case it was not a map but some kind of shader that Dale shared some...years ago.
I think you could try something like the one Ono suggests in his 'how to make a pool in sketchup' tutorial
lape
Re: Ocean Horizon
Post by lape » Sun Mar 02, 2014 8:50 pm
Pibuz wrote:I think you could try something like the one Ono suggests in his 'how to make a pool in sketchup' tutorial
works perfect, thank you.
