by Whaat » Mon Aug 03, 2009 5:32 pm
simontoplis wrote:Whatt,
Thanks for all the great work on Skindigo - have you got any idea when / if animation will be working on the Mac version?
Thanks in advance!
Simon
Animation support for Mac is fairly low on my priority list right now. However, I intend to get it working at some point. I guess my best guess for estimate would be 2-4 months. I want to first make sure that everything else works perfect on mac before I start working on animation.
by Whaat » Mon Aug 03, 2009 5:35 pm
wachenga wrote:Hi there,
Just downloaded Indigo as well as Skindigo 2.0.11d (running Mac OS X 10.5.7), put all the plugins into the sketchup 7 plugins folder, and I get this error when I select Indigo from the applications list when I first open Sketchup.
Error Loading File skindigo.rb
Permission denied - /Library/Application Support/
Google SketchUp 7/SketchUp/Plugins/
indigo_2_0_11cpath.txt
Any thoughts?
Many thanks for your time.
W
Yes, I can see what the problem is. I will work on a fix this week. New version should be available within a few days with the fix. Please check back later. Your patience is appreciated as I work out the final kinks of the Mac version.
Regards,
Dale
wachenga
by wachenga » Mon Aug 03, 2009 5:43 pm
Many thanks for the quick reply and all your effort.
W
- 3D Software: SketchUp
by Pibuz » Mon Aug 03, 2009 9:29 pm
Hi Whaat!
I'd like to suggest a little implementation for the 2.0.12 stable release (if you plan to make one: if not for the next release
ENVIRONMENT TAB -> SUN LAYER drop-down list: add "off".
This way we can spare some RAM for other light layers/bigger resolution, to simulate a NIGHT condition!
I'll add an example render ASAP.
Do you think it is possible?
by neo0. » Tue Aug 04, 2009 7:45 am
Sorry if this seems like a dumb question, but does anyone here know the latest version 1.x.x version of skindigo that supports loading of materials directly (not linked igms)? Im using 1.1.6 and it says it's been disabled
by Whaat » Wed Aug 05, 2009 2:41 pm
Pibuz wrote:Hi Whaat!
I'm not 100% sure but I don't think that it is possible to turn off the sky (or sun) if you have your environment set to Sun and Sky. The sun and sky are tied together in Indigo (currently). They can only be separated into Layers, not turned off AFAIK. If it's possible, though, I will implement it.
Time to buy more RAM
by Whaat » Wed Aug 05, 2009 2:44 pm
neo0. wrote:Sorry if this seems like a dumb question, but does anyone here know the latest version 1.x.x version of skindigo that supports loading of materials directly (not linked igms)? Im using 1.1.6 and it says it's been disabled
Neo,
The first version to fix material importing is 2.0.4. I believe it will work with Indigo 1.1.18, but you have to make sure the path is set to the right version of Indigo. There is a file called indigo_path.txt in your SketchUp/plugins folder. Either delete this file or edit it to point to Indigo 1.1.18
by Whaat » Wed Aug 05, 2009 6:23 pm
Any thoughts?
W
bug should now be fixed in version 2.0.12
cjenn86
by cjenn86 » Wed Aug 05, 2009 8:00 pm
May I know why I can't load Indigo after I have installed the plugin into my sketchup Pro 7?
It came out a window with the following words:
"Error Loading File skindigo.rb
The system cannot find the file specified."
For your information, I am using Window Vista.
by Whaat » Thu Aug 06, 2009 5:51 pm
cjenn86 wrote:May I know why I can't load Indigo after I have installed the plugin into my sketchup Pro 7?
Can you please post a screenshot of what is in your Plugins folder and your SkIndigo folder?
Did you use the Windows Installer package to install the plugin?
by Whaat » Sat Aug 15, 2009 5:01 pm
Pibuz wrote:Ok, solved THAT problem but back with a new issue here!
Perhaps you already know that, but I'd like to point it out either, just to give you something MORE to work on
So, I noticed that there are some problems when I mirror a geometry which I applied to a specular shader, like a glass or something. The problem always shows up when I flip the group/component along an axis, doesn't do anything when I copy or rotate the geometry.
It partially turns black, unevenly and strangely. It often renders black curves over the mirrored surfaces.
I don't know if you already know the problem. If not, I'll render a simple scene to show you the problem. Tell me if you need that.
Thank you a lot!
This bug should be fixed in next version. I also fixed the bug with foward slashes in the material name.
cjenn86
by cjenn86 » Sun Aug 16, 2009 5:09 am
Thanks. Everything is working well now.
Users browsing this forum: No registered users and 46 guests
