in order to use it with 1.1.18 you have to uncheck "seperate sun/sky layer" in the render settings and you cannot use quickrender. but the normal export with priority set to normal should work just fine
Cindigo 2.0.9
Re: Cindigo 2.0.9
hey tungee,
Re: Cindigo 2.0.9
oh.... just saw that even if seperate sun/sky layer is disabled <sun_layer> and <sky_layer> get exported...
sorry about that
will remove those lines in the next version. 2.0.9.1. will be there soon-ish. tomorrow or so.
sorry about that
Re: Cindigo 2.0.9
just like most settings in the export dialog
Note: Some settings in the export window are not used or broken (animation export, seperate materials/settings, etc).
Re: Cindigo 2.0.9
Oh no.
The qiuckrender button was one of the coolest things in cindigo...
matpreview is also not working.....
Re: Cindigo 2.0.9
Hey, you could just use Indigo 2.0.9
Its faster and 0.7mp is not that bad!
Cindigo 2.0.9.1 will be the last version in which I will expilcitly try to keep the compability with 1.1.18. I mean... I cannot keep 1.1.18 compatibility forever...
Oh and... no release today, i left my external drive with C4D on it at home. Sorry.
Re: Cindigo 2.0.9
Fused please could you make
an last official cindigo version with working quickrender and matpreview and sunsky?
I know that indigo 2 is faster but my wife bought an house.....
so im absolutely few with money.
Perhaps i could make an cool cindigo pdf for Cindigo therefore?
look here i made an something similar for yafaray:
http://www.yafaray.org/documentation/tutorials/dof
or
http://rapidshare.com/files/250796802/Y ... s.pdf.html
or
Re: Cindigo 2.0.9
I decided that i will release a Cindigo 1.1.18 final. It will basically be Cindigo 2.0.9, just without all 2.0 features.
It will be the last Cindigo version officially supporting Indigo 1.1.18.
- zeitmeister
Re: Cindigo 2.0.9
Oh fused, this is really more than generous!
Re: Cindigo 2.0.9
Thanks Fused, I think this is a good decision and so there is also a clear cut from the free to the new commercial version.fused wrote:I decided that i will release a Cindigo 1.1.18 final. It will basically be Cindigo 2.0.9, just without all 2.0 features.
I just wish, that Ono would release a last free but stable (and bug fixed) 1.x version too as I mentioned in other threads before.
- zeitmeister
Re: Cindigo 2.0.9
Hey fused,
I just tried to import the ghostglass.pigm from the material database and it didn't work... on Mac.
May you have a little look?
Re: Cindigo 2.0.9
David,
You're right, it does not work. For some strange reason the unpacking does not work... It works when launched manually, so i suspect an error in my batch file.
Re: Cindigo 2.0.9
Do you have non-ASCII chars in your path? For me it did not work because of that.
Importing the material works fine now. It also renders nicely.
- zeitmeister
Re: Cindigo 2.0.9
Oh, that's possible... but I thought I placed the PIGM in the same directory as the scene.
Lemme check...
Lemme check...
Users browsing this forum: No registered users and 69 guests
