from this i know you have a 512mb gpu :P basically all memory (cpu or gpu) in a 32bit os must share the same address space.Stromberg wrote:Just so you know, with 4 gb and 32-bit OS you want get to use all your ram you will only be able to use 3.5 gb. :roll:
however, even with that being the case, a single 32bit windows program cannot access more than 2gb of memory. in summary, using more than 2gb of memory with 32bit windows is retarded ;)
