Discussion for users of the Indigo Renderer SDK.
rgigante
by rgigante » Sat Feb 28, 2009 8:36 pm
well... thanks Fused.
Here are my final considerations:
if u modify driver.cpp in indigo_dll_example adding in the renderer settings a super_sample_factor = 1 and the run the code u'll see that everything works fine as you mentioned above.
But if u modify the creation of the buffer from
// Get the rendered & tone mapped image:
// Alloc a buffer
const indUInt32 buffer_width = indigo->getBufferWidth();
const indUInt32 buffer_height = indigo->getBufferHeight();
std::vector<indUChar8> buffer(buffer_width * buffer_height * 3);
to
// Alloc a buffer
const indUInt32 buffer_width = 600 //(equal to the renderer settings params);
const indUInt32 buffer_height = 600; //(equal to the renderer settings params);
u'll see that the bmp image which is created at the end of the story is totally black.
At the end of the story u have to use getBufferWidth() and getBufferHeight() to define your framebuffer (but always after the tonemapping operation otherwise they return "0") or u have to stitch on ssf > 1.
Once again something "must" be fixed.
Here my two cents.
R.
by fused » Sat Feb 28, 2009 10:09 pm
heres my tonemapping func. basically i check if the buffer size is larger than the size of the c4d buffer. if yes i just crop
Bool IndigoData::CopyToC4DBuffer(VideoPostStruct *vps)
//Get handle
IndigoHandle<IndigoInterface1> indigo = indigoClass->GetIndigoHandle();
//pause 4 tonemapping
indigo->pauseRendering();
//tonemapping output
GePrint(RealToString(indigo->getNumSamples()/indigo->getRenderTimeElapsed()));
// Start the tonemapping process. We will get a message back later, when the tonemapping is done.
indigo->toneMap();
// Wait for tonemapping done message
bool tonemapping_done = false;
while(!tonemapping_done)
indigo->acquireMessageQueueLock();
while(!indigo->isMessageQueueEmpty())
IndigoMessageInterface1* message = indigo->dequeueMessage();
if(message->getType() == IndigoMessageInterface1::TONEMAPPING_DONE)
tonemapping_done = true;
else if(message->getType() == IndigoMessageInterface1::ERROR_MESSAGE)
MessageDialog(String("ERROR: ") + static_cast<IndigoErrorMessageInterface*>(message)->getMessage());
//TODO proper error handling
return FALSE;
else if(message->getType() == IndigoMessageInterface1::LOG_MESSAGE)
GePrint(static_cast<IndigoLogMessageInterface*>(message)->getMessage());
delete message;
indigo->releaseMessageQueueLock();
if(!tonemapping_done)
GeSleep(100);
// Alloc a buffer
std::vector<indUChar8> indBuffer(buffer_width * buffer_height * 3);
if(!indBuffer.empty())
// Copy the image from the indigo DLL buffer to our buffer
indigo->copyBuffer(&indBuffer[0], indBuffer.size());
//get number of channels
LONG cpp = rgba->GetInfo(VPGETINFO_CPP);
LONG bh = rgba->GetBh();
LONG bw = rgba->GetBw();
//alloc mem for line buffer
LONG bufLength = cpp*irstruc.width*sizeof(indUChar8);
indUChar8* buffer = bNew indUChar8[bufLength];
if (!buffer) return RAY_NOMEM;
//copy indigo buffer to c4d buffer
LONG y, i;
for (i=irstruc.indY,y=irstruc.canvasYtop;y<=irstruc.canvasYbottom;y++,i++)
rgba->GetLine(irstruc.canvasXleft,y,irstruc.width,buffer,8,FALSE);
LONG j, x;
for (j=irstruc.indX,x=0;x<=irstruc.width-1;x++,j++)
LONG ip = i;
LONG jp = j;
if (buffer_width != irstruc.indWidth) {
ip += 2;
jp += 2;
buffer[x*cpp + 0]=indBuffer[((ip)*buffer_width + (jp))*3 + 0];
buffer[x*cpp + 1]=indBuffer[((ip)*buffer_width + (jp))*3 + 1];
buffer[x*cpp + 2]=indBuffer[((ip)*buffer_width + (jp))*3 + 2];
rgba->SetLine(irstruc.canvasXleft,y,irstruc.width,buffer,8,FALSE);
bDelete(buffer);
//update screen
vps->render->UpdateScreen();
if (!indigoClass->IsPaused()) {
indigo->resumeRendering();
return TRUE;
Users browsing this forum: No registered users and 69 guests
