Guys! help with lighting, light meshes and HDRI? anyone?
roville_csb
Do you mean there is a mismatch with the wiki ?dougal2 wrote:Or increase the glowIntensity of your meshlights up to several million (or so, I don't know what the value is, but keep adding zeros until it works).
roville: if you set incandescence values under the 1 1 1 range, it will become a RGB emiter. Between RGB and blackbody stands spectral emission (range 250-800 roughly).
Your later suggestion about scaling the scene to real size (setting mti_GSF to 1, 1m = 100 units, keep units cm) sounds a good approach. One can't change IES values but in the text.
