WIP and shift lens test (update p.2)
Post by BbB » Thu Jun 05, 2008 2:13 am
Sure. I'll post some screen grabs when I'm finished.
Basically, without the shift lens, you wouldn't see the feet of the table and you would see a lot more uninteresting ceiling.
In order to see the whole table without the shift lens, I would have either to lower the camera (inconvenient: very low POV with the table hiding everything that's behind it) or rotate it so that it faces downwards (inconvenients: the nice vertical lines in the image would no longer be straight but "bent" towards the bottom of the image due to the perspective).
Post by pixie » Thu Jun 05, 2008 3:03 am
BbB wrote:Sure. I'll post some screen grabs when I'm finished.
You could choose a narrow resolution (nx3n) and do a crop.
Post by BbB » Thu Jun 05, 2008 3:12 am
Not sure what you mean?
Post by pixie » Thu Jun 05, 2008 4:00 am
Leave the camera as is and instead of using a (let's say) 800x600 do a 800x 1200 resolution, then crop the surplus...
Post by OnoSendai » Thu Jun 05, 2008 4:12 am
Yes, that would do pretty much the same thing pixie.
enricocerica
Post by enricocerica » Thu Jun 05, 2008 5:32 am
Great image Bertrand !
Shifting camera is a nice improvement too in addition to displacement, so many new things in this release, I was out for a while ... I may have missed xmas :wink:
Some minor crits already mentioned, so just waiting for the final result, for sure it will be another master piece.
Post by BbB » Thu Jun 05, 2008 7:11 am
That's right but that would be very inefficient, wouldn't it? Especially if you render at 2000x2000. Who'd want to waste this precious render time?
enricocerica
Thanks man. I've tweaked a few things. Working on a night shot right now. 64-bit is really coming in handy.
Post by pixie » Thu Jun 05, 2008 8:41 am
BbB wrote:pixie
No doubt about that, the only thing going for it would be that it would bring more flexibility in the sense that you could crop from a render instead of opengl window.
zsouthboy
Post by zsouthboy » Thu Jun 05, 2008 9:32 am
You could also combine an odd resolution with a region render for the spot you need, to not waste CPU.
Or just use tilt/shift :D
Post by BbB » Thu Jun 05, 2008 9:53 am
With region render it would make sense, yes.
Post by pixie » Thu Jun 05, 2008 12:45 pm
I thought it would still waste ram... :?
Stur
Post by Stur » Thu Jun 05, 2008 11:40 pm
Oh, thx for the explanation Bertrand, it's crystal clear for me now. :D
(so no need to post quick renders with and without shift lens unless someone else was interested.)
kwistenbiebel
Post by kwistenbiebel » Thu Jun 05, 2008 11:59 pm
Stur wrote: (so no need to post quick renders with and without shift lens unless someone else was interested.)
Errr....I would love to see the before and after, and the values used.
(if possible)
Post by BbB » Fri Jun 06, 2008 9:02 am
Sorry guys. Heavy day at work. I'll post viewfinder grabs to show the difference as soon as I get a minute.
Only thing I can show is a final render of that particular scene, but only because it was cooking when I was away (about 24 hours).
If you look closely, you'll see the time stamp at the bottom. Which tells you this was downsampled by 50%.
I did more work on it than it may appear at first, but sadly it hardly shows (different fabric texture, objects on the table, redone the table mesh, which was a mess, bits and pieces added here and there).
The scene is now "night ready" and these night shots will come next.
zsouthboy
Post by zsouthboy » Fri Jun 06, 2008 9:09 am
HOLY SHIT
To the gallery, now!
BbB, I have no way of expressing how fantastic your renders are.
