Indigo 1.0.9 (1.0 stable)
Kosmokrator
Post by Kosmokrator » Fri Mar 28, 2008 8:23 am
thnx master..... :)
Post by Zom-B » Fri Mar 28, 2008 8:42 am
OnoSendai wrote:Nothing particularly cool about it, just the next compiler from MS.
I haven't really done many tests comparing speed. The new 64 bit build works pretty fast on some workloads, tho.
Hey Ono... I did some banchmarks between 1.0.8, a.0.9 & 1.0.9 64bit.
The results aren't what I expected :/
Indigo 1.0.8          =  100%
Indigo 1.0.9          =    99.42%
Indigo 1.0.9 64bit  =  100.23 %
I used the Oren Nayar testscene on 1 thread for 5min.
Prozess priority to HIGH, so Indigo don't get slowed down by anything on my System.
By repeating the benchmark there seems to be a differance for each run of +- 0.2%
Where is the ~10% speed up using 64bit gone???
dougal2
Post by dougal2 » Fri Mar 28, 2008 9:05 am
It's been gone for a while ZomB. I noticed that the last 64bit version was in fact slower on my system.
Not really surprising though, the biggest advantage with 64bit is the memory management.
dougal2
Post by dougal2 » Fri Mar 28, 2008 9:20 am
Post by Kram1032 » Fri Mar 28, 2008 9:22 am
Thanks :D
Here, on my XP64, the 64bit V works fine...
dougal2
Post by dougal2 » Fri Mar 28, 2008 9:25 am
64bit 1.0.9 is running 50,000 samples/sec faster than 1.0.4 with my standard benchmark, the diffuse transmitter test scene.
260,000 samples/sec :D
Wedge
Post by Wedge » Fri Mar 28, 2008 12:05 pm
Hello,
I have been quite busy lately but I have downloaded Indigo 108 and 109. 109 errors as soon as I run it on WinXP 32bit with one of those "this program has encountered an error and needs to close" errors.
108 launches fine but I will admit I have not started a render with it yet. My last render test was performed on version 106 I think. (106 runs fine)
I hope this bug report helped. :) Probably something to do with the new VS2008 project?
Post by OnoSendai » Fri Mar 28, 2008 7:53 pm
Wedge wrote:Hello,
Can you try running indigo_console.exe, instead of indigo.exe.
Does it give the same error?
Vanessa07
Post by Vanessa07 » Fri Mar 28, 2008 9:55 pm
I don't understand, the 1.06 64 bit works fine on my xp64, and the 1.09 make an error :?
beta
Post by beta » Fri Mar 28, 2008 11:21 pm
As all said Thank you very much Ono!!
filippo
Post by filippo » Fri Mar 28, 2008 11:50 pm
I have some problem whit 64 bit version.....32 bit work very well...
I am using vista 64 whit 3d studio 2008 64 whit pc 2xQuadXeon.
which can the problrma be?
filippo
errore message
indigo error.JPG (113.16 KiB) Viewed 7959 times
Post by OnoSendai » Sat Mar 29, 2008 12:07 am
Hi Filippo, please try running indigo_console.exe, and tell me if it gives an error.
delic
Post by delic » Sat Mar 29, 2008 2:34 am
Vanessa07 wrote:does it work with xp 64
Same pb at indigo start ! on xp 64bits !
Post by OnoSendai » Sat Mar 29, 2008 2:46 am
Someone with delic or Vanessa's problem
*Please* run indigo_console.exe and tell me what it does
Vanessa07
Post by Vanessa07 » Sat Mar 29, 2008 5:17 am
Hi ono
It doesn't want to start
Users browsing this forum: No registered users and 136 guests
