Blendigo for v1.0.8
SmartDen
Post by SmartDen » Sun Mar 23, 2008 3:28 am
Thank you for the hint, Vanessa07. I've uploaded fixed version.
Vanessa07
Post by Vanessa07 » Sun Mar 23, 2008 3:31 am
Thanks to you for your time :D
You are realy reactive :shock:
Vanessa07
Post by Vanessa07 » Sun Mar 23, 2008 4:05 am
SmartDen
In fact bump map is impossible on diffuse transmitter?
palawat
Post by palawat » Sun Mar 23, 2008 4:16 am
ok. SmartDen, what's wrong with you? I've just played with the 1.0.7
and here you are with the 1.0.8
If i were a girl i might think about marrying you. :D
Thanks very much for your time. Really appreciate it.
I'll play with it ASAP.
Cheers,
Post by OnoSendai » Sun Mar 23, 2008 4:28 am
Vanessa07 wrote:SmartDen
no bump on diffuse transmitter.
Vanessa07
Post by Vanessa07 » Sun Mar 23, 2008 4:30 am
thx Master :oops:
SmartDen
Post by SmartDen » Sun Mar 23, 2008 5:40 am
palawat wrote:ok. SmartDen, what's wrong with you? I've just played with the 1.0.7
LOL
It was not a big deal to upgrade 1.0.7 to 1.0.8, that's the reason why it was so quick ;)
And by the way, i am married ;)
SmartDen
Post by SmartDen » Sun Mar 23, 2008 5:41 am
Vanessa07 wrote:Thanks to you for your time :D
Hmm... I know, but i don't know why it was there :?:
Caronte
Post by Caronte » Sun Mar 23, 2008 6:38 am
SmartDen wrote:And by the way, i am married ;)
Ouch! :shock: :lol: :wink:
Sorry about my poor english ;)
Macrob
Post by Macrob » Sun Mar 23, 2008 7:20 am
Hi! The last blendigo version I could use was 1.0.5b. It does not even work with the simple startscene (the cube). After that version I get this message :(
processing Camera...
  Film Width 0.036000
  FOV: 49.134342
  lens-sensor-distance: 0.039375 m
  aperture-radius: 0.002461 m
build_lists
Getting Mesh from Object Cube
  File "<string>", line 2966, in drawGUI
  File "<string>", line 2759, in drawCamera
  File "<string>", line 3009, in drawButtons
  File "<string>", line 2982, in drawScreenButtons
  File "<string>", line 2358, in exportStill
  File "<string>", line 2336, in export
  File "<string>", line 2089, in exportIndigoScene
  File "<string>", line 1794, in build_lists
  File "<string>", line 1735, in getMeshFromObject
AttributeError: 'module' object has no attribute 'bpy'
Gentoo Linux 64 bit, Blender 2.45 (from blender.org) and CVS-version, Python 2.5.1
EDIT:
blendigo crashes blender on my new ubuntu 32bit install and give the same error as above with an even newer install of ubuntu 64bit (7.10) :roll:
What is happening here ... or do you all use windows?
zsouthboy
Post by zsouthboy » Sun Mar 23, 2008 9:34 am
Macrob - blendigo works fine on my ubuntu quad box
Ubuntu 7.10, blender 2.45, python 2.5.1 or 2, don't remember which.
I'll take a look to make sure...
Macrob
Post by Macrob » Sun Mar 23, 2008 9:08 pm
Hi zsouthboy! Thanks for your help! I think I did some mistake by putting blendigo*py into the wrong .blender/scripts.
It does not work in my /home/Macrob/.blender/scripts, but in the installation (?) scripts folder (at least with ubuntu).
carbon
Post by carbon » Mon Mar 24, 2008 8:00 am
hi, after a long time i decided to do something and downloaded latest blendigo. i got error, maybe from similar reasons as the one above.. as far as i remember blendigo worked well around version 1.0.1 or 1.0.2..
Getting Mesh from Object Sphere
  File "<string>", line 3014, in buttonEvt
  File "<string>", line 2329, in exportStill
  File "<string>", line 2307, in export
  File "<string>", line 2076, in exportIndigoScene
  File "<string>", line 1789, in build_lists
  File "<string>", line 1730, in getMeshFromObject
os: mac os x 10.5
blender: my own latest svn build
blendigo: blenderinstalation/blender.app/Contents/MacOS/.blender/scripts
(inside blenderinstalation/.blender/scripts it doesnt show in menu)
i am launching indigo manually.. dont even know if it is possible under osx
thanks
Macrob
Post by Macrob » Mon Mar 24, 2008 8:33 am
Hi carbon!
I made a clean .blender folder but I had to use the one in the installation folder where you can also find scripts/bpymodules/BPyObject.py
carbon
Post by carbon » Mon Mar 24, 2008 9:11 am
hmm, i got it work. inside instalation dir it doesnt work. on mac, blender, during first start, copies all the contents of .blender inside instalation into app bundle (blender.app/Contents/MacOS/.blender) and then uses it.. (i think).. but after i cleared path to my custom scripts folder it works.. but thanks, your reply made think and try some more things..
