Now I retain this option of exporting all texture frames in a row, there is work to do on optimizing animation export code (notably avoid exporting still objects for each frames
Hypershade: shading networks
Effectively there is more than one procedure to export textures, but all rely on the convertSolidTx command, if they don't just wrap it. The difference is wether a virtual plane or actual UV space are used as option, we'll get more flexibility to use that command directly depending on if the texture to compute is 2d or 3d, or if it doesn't need to rely on UVs (plain synth image).
With no doubt MtI will be using the surfaceSampler command*, it provides superior output than convertSolidTx. One of the most obvious case hereafter. This shows as I was suspecting that for some procedural 3d textures there was a hack with decreasing ratio for speed concerns, or let's call that a bug. This is history now.
The best thing is that surfaceSampler leaves the shading network inaltered, there will be no need to load the baked textures in Maya since they will be created at export only. This is totally transparent for the user.
* wrong. See 2 posts below.
- convertSolidTx
- marble1-pSphere1.jpg (57.27 KiB) Viewed 4035 times
- surfaceSampler
- sampledDiffuseColor.jpg (67.8 KiB) Viewed 4036 times
Not tomorrow, Sinister
This command is already available through Lighting / Shading > Transfer maps. Using the UI you are forced to declare both a source and target geometries, but once done it delivers the command:
The trick is to declare the same mesh as source and target, then the procedural network is simply baked at the specified place. I was amazed on how well the borders stitch, I could simply not tell where were the pole of a sphere mapped like so (if you set the option mapMaterials 1 then the texture will be attached to a new shader).
Now to answer you precisely Sinister, I can honestly not tell you when, but soon, certainly
surfaceSampler -target pCubeShape1 -uvSet map1 -searchOffset 0 -maxSearchDistance 0 -searchCage "" -source pSphereShape1 -mapOutput diffuseRGB -mapWidth 1024 -mapHeight 1024 -max 1 -mapSpace tangent -mapMaterials 0 -shadows 1 -filename "C:/work/3d/Indigo/textures/sampledDiffuseColor" -fileFormat "png" -superSampling 1 -filterType 0 -filterSize 3 -overscan 1 -searchMethod 0 -useGeometryNormals 1 -ignoreMirroredFaces 0 -flipU 0 -flipV 0Now to answer you precisely Sinister, I can honestly not tell you when, but soon, certainly
Now the sad part with surfaceSampler is that it will work for albedo and displacement only. convertSolidTx will be used then for other shaded material parameters, but at a higher dev cost than expected (materials are exported in a standalone fashion, information on the surfaces they are applied to is not retained at this point).
So... not that soon I fear
