SkIndigo 1.0.4
lorom
Post by lorom » Sat Jan 05, 2008 11:25 am
it always happens! :(
lorom
Post by lorom » Sat Jan 05, 2008 11:30 am
this happens when I launch a material editor
xrok1
Post by xrok1 » Sat Jan 05, 2008 3:21 pm
whaat, i havn't been able to get the previews working. i was getting an error, then i noticed your post about renaming the previews folder. now i get no error but i get no preview either. do you know whaats :lol: going on? (indigo1.0.4)
Post by Whaat » Sat Jan 05, 2008 3:43 pm
lorom,
The material editor looks fine to me!
Check your private messages. I will send you a special test version of SkIndigo.
xrok1
Post by xrok1 » Sat Jan 05, 2008 4:16 pm
my bad i had skindigo 101 installed still
now i've installed 104, when i hit preview indigo opens and renders the mat.
i just tried a different mat. and got a message "thumbnail path not found. preview aborted"?
BTW what does "Aperture Diffraction" do?
Post by Pibuz » Sat Jan 05, 2008 10:56 pm
Hi Whaat!
I re-downloaded v1.0.4, re-copied its folders in the right place, deleted the log files i found and lauched SU: everything is now ok! :D
Thank you so much!
lorom
Post by lorom » Sun Jan 06, 2008 10:13 am
hi pibuz can you tell me the steps that you did.
I mean...where you placed the indigo folder?
Which log file have you deleted?
lorom
Post by lorom » Sun Jan 06, 2008 10:16 am
yes whaat it looks fine to me too but I should see the image in the square on the top (at thr right) of window...I think!
Anyway when I try to launch the rendering I see the message "fatal error"
xrok1
Post by xrok1 » Sun Jan 06, 2008 10:52 am
its wierd, now its working fine. maybe i just needed a reboot :wink:
xrok1
Post by xrok1 » Sun Jan 06, 2008 11:00 am
oops, wrong again.
here's what i found: i have a table component, if i open that .skp file i can preview materials; but if i open my house .skp with the table component inside of it and try to preview the same material off the table i get the "thumbnail path not found. preview aborted" message.
any thoughts?
Post by Whaat » Sun Jan 06, 2008 11:03 am
Pibuz wrote:Hi Whaat!
Thank you so much!
Great! Which version are you referring to? The one posted in this thread or the one that I sent you with the private message??
Post by Whaat » Sun Jan 06, 2008 11:11 am
dbl post
Post by Kram1032 » Sun Jan 06, 2008 11:27 am
Dump, that I steal you that option, now, but when you're the last poster, you can press the "x" in order to erase that last post...
xrok1
Post by xrok1 » Sun Jan 06, 2008 12:01 pm
am i being ignored? :(
... or stupid? :?
Post by Whaat » Sun Jan 06, 2008 1:51 pm
xrok1 wrote:my bad i had skindigo 101 installed still
If the thumbnail path is not found, you must manually edit the thumbnail path to a valid path. You might have changed your directory structure or folder names so that SkIndigo can no longer find the thumbnail folder. Just edit the path manually to wherever you want your thumbnails to be saved and it should work.
Aperture diffraction is explained in the announcement for the release of Indigo 1.0.4. A forum search would have answered this question as well. :wink:
Users browsing this forum: No registered users and 46 guests
