(I already have an idea, what it could be...)
a french merry christmas!
thank you for the nice appreciations
for Kram1032: the render with bubbles. It seems that the champagne is like a black hole... It absorb all the light... I've done another render with the champagne(in fact 2 champagne?!) outside the glass to confirm it.
If you have any clue about that (I've seen a similar problem I think on this forum about the blender' monkey but I didn't really undertood the solution...
) (so, sorry about the bubbles, they won't be visible until I have solved the problem.......)
- black hole champagne
- im1196157334.png (745.5 KiB) Viewed 2209 times
- the champagne oustide the glass
- im1196190062.png (715.6 KiB) Viewed 2209 times
thanks for your help!
kram1032 is right, in fact the two pictures are inverted... the render with the champagne outside the glass to show that the reflects are due to the glass....
I've tried to switch the normal yet, I'll try again (maybe I was a little tired...).
I don't understand the meaning of this suggestion:
Is it about the object? the material?
BbB wrote:Is your scale correct?
