Sry, but I don't understand what you are talking about. Can you explain in a bit more detail?vansan wrote:Suvakas, please, make an option for Maxigo to include .igs files in exported scenes. This would keep me from copy-pasting stuff monkey-job, thanks in advance!
Maxigo 0.9.4a
I think it's a must-have function for testing personal-written modules.
Here is the code for IES-Lights. Hope this helps.
And this is Meshlight_IES.igm file code:
--scenescale =
format"<include><pathname>C:\Indigo\scenes\meshlight_IES.igs</pathname></include>\n\n"
for iL in lights do
try (if iL.distribution == 3 then
--ies_xposition = iL.pos[1] --/ scenescale
--ies_yposition = iL.pos[2] --/ scenescale
--ies_zposition = iL.pos[3] --/ scenescale
format "<meshlight>\n<pos>% % %</pos>\n" iL.pos[1] iL.pos[2] iL.pos[3] --ies_xposition ies_yposition ies_zposition
format "<scale>1.0</scale>\n<mesh_name>lightmesh</mesh_name>\n\n<spectrum>\n<blackbody>\n<temperature>%</temperature>\n<gain>1.0</gain>\n</blackbody>\n</spectrum>\n\n<ies_profile>\n<path>%</path>\n</ies_profile>\n</meshlight>\n\n" iL.kelvin iL.webFile
else())
catch()
<mesh>
<name>lightmesh</name>
<normal_smoothing>false</normal_smoothing>
<embedded>
<expose_uv_set>
<index>0</index>
<name>albedo</name>
</expose_uv_set>
<vertex pos="-0.02 -0.02 0" normal="0 0 -1" uv0="0 0" />
<vertex pos="-0.02 0.02 0.02" normal="0 0 -1" uv0="0 10000" />
<vertex pos="0.02 0.02 0.02" normal="0 0 -1" uv0="10000 10000" />
<vertex pos="0.02 -0.02 0" normal="0 0 -1" uv0="10000 0" />
<triangle_set>
<material_name>white</material_name>
<tri>0 1 2</tri>
<tri>0 2 3</tri>
</triangle_set>
</embedded>
</mesh>
suvakas,
i dont know why when i export an interior scene it took me 6min to export to xml and is this normal?
6min is unacceptable cos the interior has only 150k polys and other applications could do that under 1 min.
Export to 3ds = crashes(mesh error)
Export to obj = long "Doing initial warmup" (around 2 min)
Export to xml = long export + error
in the end i get frustrated cos didnt render anything
EDIT: When i export to obj format it only process something like 400 samples/s .. now when using xml, increased to 44ksample/s
thanks
thanks
Thanks for this Suvakas! I haven't been around in ages (to busy with work) but great to see this stuff still going on!
Website
http://www.surrient.com/
Excellent! Working in a Game studio in Vancouver now, which takes up a lot of my time (well with my 2 hour each way commute it does!) What about yourself?
Website
